• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
1.9D Leaking expansion tank cap
Sign in to follow this
Followers 0
10 posts in this topic
I have a curious leak on a 1.9D expansion tank pressure cap. After a journey there are signs of coolant seeping from the pressure cap. I have checked the following: 1. Replaced the pressure cap. 2. Replaced the pump. 3. Checked all hoses for any blockages. 4. Checked the oil filler cap and dip stick for signs of coolant in the oil. None, therefore assume the head gasket is sound. I have noticed that cooland continually flows into the expansion tank from the small hose that comes directly from the cylinder head. My other 1.9D does not do this! Could this indicate a problem somewhere? The hoses are not overly pressurised when running. Most grateful for any comments on this if anyone has had similar symptoms. Many thanks.
Share this post
Link to post
Share on other sites
it could be that the headgasket as failed on one of the exhaust ports which pressurises the system and the coolant cap is venting the pressure when it gets to its release presure psi, i would get the head tested because if the above is happening you wont see mayonaise as such in the water or oil.
Share this post
Link to post
As above, it could still be the head gasket. If the pull looks ok that means it's not leaking between the water and the oil but it could be leaking between the water and combustion chamber and thus pressurizing the water.
Share this post
Link to post
Is the engine overheating? What is temp. gauge showing? Cooling fan kicking more often? To what level is coolant rising in expansion tank? Too much coolant?
The cooling system is normally pressurized, but as above, you may have too much pressure that may come from a small crack in head gasket or worst case scenario cracked cylinder sleeve/engine block.
The easiest way to find out is to test if the coolant is contaminated with combustion residues. Car shops have a special liquid that changes color when mixed with contaminated coolant. There are lots of videos on YouTube about that.
Edited by adurer
Share this post
Link to post
Similar to the above, my friendly MOT station put the probe they normally stick up the exhaust into the header tank. Not right into the coolant, just place the end in the top and if there are exhaust gases in the coolant it will register on their machine.
Share this post
Link to post
Happened to my 1.3 felicia gradually got worse turns out it was head gasket but while I had it off sent it for skimming to give a little boost ;) dearest parts for 1.3 was the gasket kit
Share this post
Link to post
Hi guys, Thanks for all the suggestions. I have not solved the issue as events have overtaken the repairs.Last week the car was back-ended. Assessor has written it off and settlement from third party insurer is £750. Repair estimate came to over £3,000!!!! I'm happy. Have replaced it with a 2001 Fabia 1.9Tdi Elegance Combi with every extra except cruise control. Thanks anyway.
Share this post
Link to post
Let's see if I can back-end my car too then buy that 3,700 miles white Felicia on eBay...
Share this post
Link to post
IIRC that can be easily retro-fitted. (It's a doddle on the Octy apparently)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
