No bend lighting (AFS) function
bend lighting AFS
  • Please log in to reply
26 replies to this topic
#1 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
  • Car:59/2010 Superb II 2.0 TDI Elegance Twindoor
Posted 24 August 2013 - 09:24
Hello all,
New to Skodas and to this site. I've just purchased a MY 2010 Superb Elegance, which has a fault coming up on the display within about a minute of turning on the ignition of an orange bulb with an exclamation mark, and the error "No bend lighting (AFS) function" in the display (is this what's referred to as the Maxidot?)  I'm guessing this fault is related to the self-levelling for the headlights as they are not doing the little 'dance' when first turned on with the light switch turned to 'Auto'.
I've searched through the site before posting, and it's been suggested this may be related to "Tourist Mode" but I cannot find this setting anywhere in the Setup menu (In Lighting & Vision I only have: Coming Home, Leaving Home, DRL, Comf. indicators, Factory Reset and Back). I don't think it's the cornering function of the foglights as they are turning on/off as I corner with lights on.
I would welcome any suggestions or guidance of what/where to check.
Thank you
Edited by Figment, 24 August 2013 - 09:25.
#2 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 24 August 2013 - 10:09
Just to add to this if relevent, the offside headlight appears to be swivelled left (towards the nearside kerb) when the nearside headlamp is closer to pointing directly ahead.
#3 jonteflon
jonteflon
    Newbie
  • Members
  • Pip
  • 13 posts
Posted 24 August 2013 - 10:50
When I've had tourist mode enabled it didn't give any messages as far as I recall.
I think the option was in the Columbus system. I'll have a look when I'm next in the car.
Jon
#4 dippo
dippo
    Member
  • Members
  • PipPipPip
  • 170 posts
  • Car:Superb Elegance Hatch TDi 2.0 CR170 DSG
Posted 24 August 2013 - 11:31
From that thing called the manual:
Tourist light
This mode makes it possible to drive in countries with opposing traffic system,
driving on the left/right, without dazzling the oncoming vehicles. When the mode
“tourist light” is active, the above mentioned modes and the side to side swivel of
the headlights is deactivated.
The mode “tourist light” is activated/deactivated via the information display in
the menu:
? Settings
? Travel mode
? Off
? Switched on
#5 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 24 August 2013 - 11:54
Jon
I've looked through all of the settings in the Columbus system to no avail. Appreciate you taking the time to look.
Tourist light
the menu:
? Settings
? Travel mode
? Off
? Switched on
As unbelievable as it may sound, I did actually look at the manual before posting, but the settings menu in the car does not have 'Travel mode'
#6 milesunder
milesunder
    Member
  • Members
  • PipPipPip
  • 209 posts
  • Car:2012 62 Skoda Superb Estate L&K 2.0tdi 170 4x4
Posted 24 August 2013 - 20:21
I think I might be able to answer this one. It sounds like you have a faulty sensor. This happened to my Superb a couple of months ago and the dealer found water in one of the headlamp levelling sensors in one of the wheel archs. They replaced the sensor under warranty and haven't had the problem since.
Hope this helps?
  • Figment and sweetooth like this
#7 JakeBlade
JakeBlade
    Uber Member
  • Members
  • PipPipPipPipPip
  • 1,485 posts
Posted 24 August 2013 - 20:27
The Tourist setting is in maxidot, not Columbus.
#8 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 24 August 2013 - 20:37
Hope this helps?
Thanks for replying, it's the best I have to go on so far. I checked all round the back of the headlights for loose connectors etc. (none found) I did notice that, on switching headlights on (Auto mode with the light sensor covered to simulate darkness) the offside headlight was shaking very slightly for a few seconds as if the servo motors were attempting to move it. The nearside however did not move. Car is over 3 years old, so no warranty.
I've looked there too. Unless I'm being a total numptie, I have nothing in any menu on maxidot or Columbus that remotely resembles 'Travel mode'
#9 milesunder
milesunder
    Member
  • Members
  • PipPipPip
  • 209 posts
Posted 24 August 2013 - 20:42
Reading the thread again it would definitely appear that there is a fault. This error message is effectively limp home mode for the lights.
If one of the lights is pointing left it would indicate that maybe the headlight is at fault.
This message would not come up in Tourist mode. When driving in France last month with my Superb I had this mode set and the only indication you have that tourist mode is set is the flashing of the bulb warning lamp several times when you turn the ignition on.
Again I hope this helps?
  • Figment likes this
#10 JakeBlade
JakeBlade
    Uber Member
  • Members
  • PipPipPipPipPip
  • 1,485 posts
Posted 24 August 2013 - 20:45
Maybe tourist mode has been de-activated from Maxidot because of the problem with the AFS?
#11 countryboy
countryboy
    Briskodian
  • FREEDOM
  • PipPipPipPipPip
  • 1,560 posts
  • Car:2013 62 plate Yeti 170 4x4 Elegance and 2006 Sterling Eccles Diamond
Posted 24 August 2013 - 20:50
It won't be tourist mode, it is a fault as the car is telling you it is by having the warning light and text come up on the dashboard, you need to go to the dealer or someone with VCDS to find out what the fault code is and what needs replacing.
Ian
#12 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 24 August 2013 - 21:15
Thanks for all the replies. I realise there's is a fault, I was vainly hoping someone might have experienced the same and tell me to check the black thingummy behind the whatchamacallit. Looks like a trip to the dealers then, as I have no idea what VCDS is, or how to find someone that has it (I'm guessing it's some kind of diagnostic device?)  Any ideas on cost just to diagnose the fault?
#13 KBPhoto
KBPhoto
    Addict
  • FREEDOM
  • PipPipPipPipPipPip
  • 7,302 posts
Posted 24 August 2013 - 22:05
Look here: http://www.briskoda....own-as-vag-com/
Pay in 'beer'.
#14 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 25 August 2013 - 15:31
Pay in 'beer'.
Thanks for the link. I tried messaging the member closest to me with the correct cable, unfortunately he is unable to receive PMs :(  Will try some others
#15 Graham Butcher
Graham Butcher
    Finding my Feet
  • Members
  • PipPip
  • 83 posts
Posted 14 September 2013 - 12:32
Don't operate the headlights manually, leave the headlight switch in the AUTO setting and then they will switch when it gets dark enough and should also swivel as you go round bends etc.
Hope it works OK.
#16 Figment
Figment
    Finding my Feet
  • Members
  • PipPip
  • 53 posts
Posted 14 September 2013 - 13:09
Thanks for your reply.
The issue was resolved yesterday. My local dealer diagnosed a faulty module on the offside headlamp. When they started dismantling the car to replace it, they further discovered the offside headlamp was not an original Skoda unit (which should have been spotted earlier, seeing as it didn't have the 'Superb' badge on the side), and the reason VCDS was reporting a faulty module was because the module didn't exist!
One new genuine headlight (and, presumably, module) later and the fault has gone, although I haven't yet driven the car in the dark to check the bend function actually works.
I also now have 'Travel Mode' available on Microdot (not that it will ever be used!)
#17 markthetaxi
markthetaxi
    Newbie
  • Members
  • Pip
  • 6 posts
  • Car:superb elegance 170hp
Posted 22 January 2015 - 10:10
No Bend lighting warning.
After hitting a pot hole hard on o/s I have now got no bend lighting warning. Is this a main dealer investigation, or is anyway of resetting or manual adjustment. Lights all work apart from self levelling mode .
#18 silver1011
silver1011
    Briskodian
  • FREEDOM
  • PipPipPipPipPipPipPip
  • 16,034 posts
  • Car:2016 Skoda Octavia 2.0 TDi CR150 Scout, 2011 Skoda Superb 2.0 TDi CR140 SE Twindoor
Posted 22 January 2015 - 15:40
The shock from the pothole has likely broken or knocked something inside the headlight.
Unless you are confident to do it yourself then a dealer will need to open the back of the headlight and see what the issue is.
#19 Superb170
Superb170
    Member
  • FREEDOM
  • PipPipPipPipPip
  • 2,521 posts
Posted 22 January 2015 - 17:23
The bi-xenon unit is an expensive and sensitive piece of kit so I'd wary of having a go myself and definitely wouldn't if under warranty.
#20 vrsadz
vrsadz
    youngest briskodian to own a superb twindoor
  • Members
  • 8,366 posts
  • Car:skoda superb 170 cr elegance twindoor
Posted 23 January 2015 - 05:49
Check the headlight bulb are lit a mate had it on his insignia and changed the headlight bulb and all was ok
#21 markthetaxi
markthetaxi
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 30 January 2015 - 18:37
Have taken car to local multi franchise dealer Skoda authorised .
Couldn't get to bottom of fault had it all day including taking bumper off. Gave it back without charge but now o/s headlight pointing into kerb !
Now what another Main dealer?
#22 ric04vrs
ric04vrs
    Big dog = big car
  • FREEDOM
  • 8,293 posts
  • Car:candy white Superb estate SE+
Posted 31 January 2015 - 08:53
Not sure how the levelling set up works on the Superb, but on Volvos there is a levelling sensor mounted to the O/S inner wing under the arch with a link down to the wishbone, could this have been damaged by hitting the pothole on that side ?
#23 sweetooth
sweetooth
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Car:2009 superb pacific blue,dsg 170 combi
Posted 01 February 2015 - 19:22
hello all had the same problem with mine local skoda dealer decided first it was a sensor on the n/s suspension ,but that was not the case.They did a diagnostic  check and found it was a faulty  headlight unit which sits behind the dashboard .All ok now but I'm £400 lighter ,  I hope the info is useful to you.
#24 markthetaxi
markthetaxi
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 05 February 2015 - 11:58
I have found secondhand Zenon headlight on eBay £136 delivered hope this sorts it out £40 to fit by ex Skoda mechcanic.
#25 Alvaro
Alvaro
    Briskodian
  • Members
  • PipPipPip
  • 184 posts
  • Car:2013 Superb II Combi TDI 170 DSG (company car), 2008 Mazda 6 2.0 CRTD 5 door (family car)
Posted 08 February 2015 - 21:16
I experienced the same warning message (""No bend lighting (AFS) function") on the MFD two days ago, after washing the car. Yesterday I didn't drive the car. Today the message had gone and the AFS worked properly.
A faulty/wet sensor?
#26 milesunder
milesunder
    Member
  • Members
  • PipPipPip
  • 209 posts
Posted 09 February 2015 - 22:22
I had this on mine where the fault was intermittent. Blade Skoda identified it as a faulty sensor in the wheel arch full of water. Not sure the price to fix it as it was covered under warranty.
#27 markthetaxi
markthetaxi
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 27 February 2015 - 08:59
Finally sorted problem Headlight control unit £370 inc initial diagnosis test .
Not headlight unit I bought on eBay . So now have o/s Zenon headlight for sale £136 delivered if any takers?
