• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Key programing
Sign in to follow this
Followers 0
4 posts in this topic
Hi I have Skoda octavia SDI year 2003 receantly I've got new key for it because I lost my original one. The new key works and it's fine. Then I have fount my oroginal key which still can open the car but It won't start it. I was looking on methot with 2 key and from door but because I don't have remote locking on this car that can't work.
Is there any other suggestion how to get it work ???
Share this post
Link to post
Share on other sites
Sounds like the immobiliser chip on the new key is a different code to the original one. Did the a garage supply the key? They may have reprogrammed the car for the new key's immobiliser code which is built into the key body.
I am guessing that you don't have the key tab which is supplied with new cars and gives the dealer the code for ordering the correct replacement key.
Getting a new key cut from a blank will only allow the door to be opened etc but not to start the engine.
Share this post
Link to post
right! this will clear things up
Firstly the sync method is purely for the remote locking & has nothing to do with the immob or starting the car
Secondly, when you lost your original key it was deleted from the immob when your new key was programmed. When people get a spare key done the the original key has to be programmed again with the new key, any not not done get deleted. You can't just add a new key like you can with other makes such as Ford etc.
Thirdly, even if you have the key tab & you order a key from the dealers it doesn't come pre-programmed to the car. They order the key to details stored with chassis number etc. The blade comes pre-cut but they still have to program the key into the car so it recognises it. The immob chip in the new key is blank until it's programmed regardless of where you get it from
Craig
Share this post
Link to post
also if you want your original key programming back in so you have 2 fully working keys i can probably help out. I have various bits of VAG equipment for reading a cars SKC(pin code) & programming keys in
I travel all over the country with work so will possibly be near you at some point
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
