Hybrid turbo arrived
Recommended Posts
Think i'd need an oil line gasket too mate, just want to get the parts list and order them then i'm ready to do it.
How hard is it to fit it yourself? I have no idea what is required, i've taken the inlet manifold off before so it can't be much harder than that surely?
Link to comment
Share on other sites
downpipe "gasket" is fine to just use exhaust paste - just want a new exhaust manifold gasket which can be had for south of £10 usually.
The fiddly bit with a turbo is usually the oil drain & feed, and also ensuring the actuator is setup right, stopscrew is setup accurately, and turbo is clocked correctly for where the outlet should point on a vRS. :)
Link to comment
  • 8 months later...
Sorry to pull up an old thread.
Looking at going down the route of a replacement turbo as a preventative measure (starting to get a metallic ticking/rattling on boost in 3rd and has been 'fluttering' for a month or two under boost too.  Drives fine otherwise.
Have I missed any crucial parts? - Looking at the above, I should just need:
-Turbo (comes with oil drain gasket)
-Exhaust Manifold Gasket
-Oil & filter
Most say that the oil pickup pipe on a Fabia will be fine unless damaged during removal.  But should I be purchasing anything else from the dealers/darkside?
Thanks!
Link to comment
Thanks for all the pointers on parts/ gaskets needed. Would have ordered the wrong oil line!
Letting a mechanic take a closer look first as although the Turbo is probably due for replacement, the ticking could apparently be injector related / camshaft wear. Wonderful...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
