• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
camshaft sensor and fault code problems
Sign in to follow this
Followers 0
3 posts in this topic
Got a mk1 skoda octavia vrs! Engine manegment light was on fault code po341 was comin up meaning it was needin new camshaft sensor! Replaced the sensor cleared the code and car started no problem! Ran it for 5 min then turned it off started it again and it took 3 turns to start and engine manegment light is on again! Does anyone know what the problem could be would be a great help
Share this post
Link to post
Share on other sites
Is it the same fault code thats coming up? If so, theres a good chance the crank sensor is the fault not the cam sensor
Share this post
Link to post
Yes its the same code comin up everytime! Been told it might be the reluctor wheel thats damaged but cant find anything about people havin problems with that! Never thought of that crankshaft sensor could try that
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
