engine missfire woes
jimmytip
Recommended Posts
i am getting intermittent missfire on 1.9  130 bhp. fuel filters been changed and i have tried several different garages for fuel. it can sometimes go 3 or 4 days without bother then out of the blue start again! nearly 200,000 on clock egr valve changed 33,000 miles ago. please help im demented!
Link to comment
Share on other sites
The wiring loom for the injectors inside the engine is a frequent cause of intermittent misfire on the PD engines. After a high mileage, the loom becomes brittle and the connectors intermittent. Often, there is no fault code.
The loom is cheap and easy to change in-situ. Warm the new one before you fit it, so the carrier becomes flexible. Despite a sharp bend, it goes in without a problem.
200k miles is about run in for a 1.9 PD.
rotodiesel.
Edited by rotodiesel
Link to comment
rotodiesel.
thanks for quick responses, no fault on cars dash, havnt had diagnostic done yet but wiring change is all i have left to do. i will be at garage first thing tomorrow! is it a dealer part only? thank you for your help.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
