Wheel bolts loose!
Recommended Posts
I'm a mechanic to trade and yet never had anything like this.
Major work on the VRS last month including brakes, suspension and four new tyres. All great, no problems, finished as I would normally do including torquing the wheels as specified.
1400 miles later, after all sorts of driving - commute, around town, motorway, fast countryside. The wheel bolts on the left front have loosened off! WTF?
Anyone else had this? Everything on that corner seems completely normal, nothing hinted at a problem until this happened.
Link to comment
Share on other sites
Will be checking mine this morning...
I have heard someone say that they should be rechecked after a few miles to make sure they are still the correct torque but I've never heard of them coming loose as such. Seems strange!
Link to comment
Old saying never buy a mechanics car LOL
Seriously though the mind boggles what could have happened if that wheel came off.
Some use of locktite on ALL those wheel nuts, springs to mind ASAP
So glad your in one piece to tell the tale.
Link to comment
I'm a HGV Mechanic by trade, Can't say loose wheel nuts are a new thing.
Never had any come loose on my car though, Whenever ive had a wheel off they are Torqued up and checked twice, then i check again say 500 miles.
Link to comment
I'd think that Locktite especially the lovely green one would work very well, be just as good as a Kwikfit fitter's air gun - though I'd never ever plan to try either of these methods!
  • Like 1
Link to comment
Guest BigJase88
This is what happens
6489_102324576444993_1569050_n_zps1d6693
Link to comment
Did the brake disks have paint on the hub part, it sounds like you either missed to torque that wheel or something between the wheel and hub has compressed thru a few heat cycles,if you are going to lose a wheel it is usually the nearside that comes loose.
Link to comment
Why the nearside felicia16v?
Standard alloy and bolts, defo torqued and check torqued all wheels after fitting and then a few miles. A smear of copper slip between wheel and disc surface to stop sticking.
No locktite anywhere near them!
Link to comment
I did a little front caliper cleanup yesterday after getting some nasty squeaking,
Had the opposite problem, I have never come across wheel nuts on so tight!
I'm not a small lad.... in-fact quite the opposite! im a fat old man...  if it takes my full weight jumping on a breaker bar to crack a nut off my guess is the person that put them on was in-fact "The Hulk!"
Link to comment
A colleague of mine took her campervan (converted transit) to have some work done.
The garage didn't tighten the wheel bolts properly and the wheel came off on the motorway!
She was very lucky and was able to not crash. Garage very apologetic and sorted any damage etc out.
You are supposed to check them after a few miles.
Phil
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
