VCDS Lead
BTS22
Recommended Posts
Wanting to download myself VCDS and get to learning how it works/how to use it so looking into the leads to plug into the OBD port and then the laptop.
Can anyone recommend any?
Was gonna go for something like this;
http://bit.ly/1kUnKTm
Advice appreciated...
Link to comment
Share on other sites
I just bought one of these:
http://www.ebay.co.uk/itm/171175298869
And haven't had a lot of luck with it. Was able to communicate with the ABS module but nowt else. Loads of "communication errors" Not sure whether its laptop, wiring problem or the cable. I've read it can be a bit hit and miss with some of the ebay cables, so I'm hoping I just got a duff cable. It seems some people have no trouble at all with the ebay cables.
Have now put in an order for one of these:
http://www.gendan.co.uk/product_VAGUSB.html
To see if I have a bit more luck with it, as I read that Gendan are one of the UK Distributors for ross-tech stuff. http://www.ross-tech.com/distributors.html
Good luck.
Edited by 06vrsandy
Link to comment
To see if I have a bit more luck with it.
Good luck.
Try increasing the port latency a bit - sometimes it helps to get around the connection problems on cheap cables
Sent from my Nexus 7 using Tapatalk
  • Like 1
Link to comment
Advice? Buy the real thing!
Second that, bought mine from gendan. Buy the real thing!
I tried a eBay one a few yeard ago and couldn't do anything waist of money. You won't be disappointed buying the real thing.
Sent from my SM-G900F using Tapatalk
Link to comment
I've got a Gendan Maxscan which has been extremely useful and does what it says in their blurb.
Oh, sometimes it's a bit reluctant to reset service indicators but otherwise brings up all'fault codes'.
Link to comment
Hence asking you lot on here, not clued up on it at all!
Is the Gendan one the real deal then?
Appreciate the help.
Link to comment
Gendan is a company who sells the real thing. Put gendan VCDS in Google and it will bring them up. Cost me £280 from them.
Link to comment
VCDS lite is about £60 for the license or you can use the trial download which is free but not everything is enabled.
For the VCDS lite lead. Ross tech don't make/sell one so buy a third party one of eBay for less than £10
So
VCDS £260 can be used on newer VAG.
VCDS lite £70ish limited to the older cars
VCDS has no advantage over the Lite version for the fabia mk1.
Edited by faboka vrs
  • Like 1
Link to comment
So
VCDS lite allows you to do module coding now?
Link to comment
When registered for $99 it does. However it is linked to the computer it is installed on. To transfer it to another machine you need to get a code from Ross tech and I think there is a limit to the number of times you can do this. With full fat VCDS the license is in the cable and you just use it with whatever computer you want.
Also with a proper Ross tech cable I have had zero connection issues.
Link to comment
Nice one mate, turned down the latency in the advanced settings of the com port in device manager and performance improved.
Still can't talk to the 01-Engine though. Tried higher latency too, that didn't help. I'll see if the GenDan cable has any luck. If not something must be shafted...
Link to comment
  • 1 year later...
Guest
  • Community Partner
  • Create New...
