Has anyone managed to run a cable through the engine bulkhead
Recommended Posts
I need to fit some control equipment that needs a cable about a pencil in diameter , I need to get this from the cabin to the engine bay, before I start rummaging around has anyone done something like this ? Ta
  • Like 1
Link to comment
Share on other sites
On my 1212 estate there is a large bundle of cables that go through under the battery..
I removed the battery, then the foam cover under the passenger footwell & pushed a hook through (about 4inch long) then simply pulled the bcable back.
There is  a large fuse box next to the battery & there are spare 5/6mm stud that you can fit a ring terminal onto.
Quite easy (once I got the battery off & found the loom.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
