Which clutch / DMF kit?
Recommended Posts
How do I know which manufacturer of clutch & DMF I have fitted?
I've been told that they need to take half the engine out to find out for certain...
Reason for asking is that I might be able to get a LUK kit very cheap, but am not going to try unless I know it is that one I need.
Does it matter if it is a Sachs kit now and I get a LUK one fitted (it's a 2007 Octavia so no warranty issues)?
Link to comment
Share on other sites
AFAIK either can replace either, as long as you fit them as a complete kit, ie don't try using a Sachs clutch with LUK dmf, and vice versa.
Can anyone confirm this?
Hopefully I can get the complete LUK setup and anything else I need in one go.
Link to comment
Dunno.
When I booked it in, Tony didn't ask - as if I would know - they just had the parts on the rack when I arrived. From that I assume it doesn't matter.
While it may make sense to VAG to be able to source sub assemblies from a range of suppliers which may be different to avoid patent infringement etc, changing anything fundamental VAG made to suit, like crank PCD, could lead to a logistical nightmare.
The logic would seem to point to the whole being interchangeable, but not the individual components within the sub assembly.
If that makes sense.
Give shark a call n' ask.
Link to comment
I understand the manufacturer making their clutch compatible with their DMF but not necessarily that of another manufacturer, but if I get a LUK clutch kit & DMF can I fit that irrespective of what is currently fitted?
Or am I taking an expensive gamble?
Link to comment
Because the 1.9 is so much more refined with SMF
Mike
I meant, why won't the 2 litre take a SMF?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
