Garret turbo gasket?
Jay29
Recommended Posts
As per title I have picked up a PD130 Garret turbo GT1749VA off an Audi A3
My question is... Which gaskets will I need to fit this unit? Are they the same gasket sizes used on the KKK?
I would like to get this turbo cleaned up and bead blasted to make it look spanking but no one does the job?
Not turbo dynamics, not turbo technics
Someone must do it??
All I'd have to do then Is get a new turbo oil feed, and clock the unit... Happy days
Contemplating to fit as soon as or wait for kkk to fail if it does
Link to comment
Share on other sites
Cool seen a gasket set on eBay for 20quid
Mine is a blt model... So will need clocking to fit, my egr pipe is still in place, is the egr cooler joined to this pipe? Do not want to delete
Edited by Jay29
Link to comment
That'll depend massively on what turbo you've actually bought and what it came off.
I put a BLT turbo on my ASZ engine and the EGR didn't line up due to the different EGR arrangements between those engines and the fact that that meant a different cast exhaust manifold attached to 2 identical turbos.
I'd imagine it'd be a massive fluke if the turbo you've bought happens to just bolt straight on with everything being able to remain in place....
Link to comment
It was a ASZ
Mine is BLT with blanked EGR however my pipe is still in place as I kept oem look
If I clock and fit the Garret gt1749va would I lose the EGR cooler pipe? Are they joined?? Would this mean that I'd have no choice but to delete?
Link to comment
If Garrett make them the same as KKK (and I assume they'd HAVE to have the same exhaust manifold) then the connection to the EGR will be a different length and position on the 2 manifolds
BLT turbo
ASZ turbo
The casting of the BLT was shorter to allow for the extra pipework for the EGR cooler (fitted to help the later engines on emissions)
When I did BLT turbo on to ASZ engine it was fine cos I just blanked off the hole in the manifold, removed the pipe from the underside of the EGR and blanked that hole too.
EGR assembly stayed in place but given the lack of interaction with the exhaust manifold it was not operational.
All vac pipes stayed attached meaning no dash lights meaning no need to do a remedial remap.
I'd imagine the same will be true of the reverse ASZ on to BLT swap but obviously with the EGR cooler thrown in to the mix
Link to comment
Cheers pastyboy mine is already mapped so no CEL
My only concern was the egr cooler pipe I wanna leave many pipes in place as possible and don't wanna b buying a delete kit and egr cooler hose
Link to comment
There's a difference between being mapped for performance and being mapped to account for the removal of the EGR.
I think they tinker with 2 different areas of the ECU.
As said on my ASZ I had to take the pipe that connected the exhaust manifold and the EGR valve out.
Cos when I put it together it looked like this
I removed the pipe completely and just blanked the two holes (one in the manifold one in the EGR) everything else remained in place and everything functioned correctly.
removing the pipe and blanking those 2 holes is essentially the pikey version of an EGR delete as it does exactly the same job (and is £13 rather than £93)
You may be able to do something similar on your BLT engine, but you will lose the operation of your EGR valve.
The BLTs separate EGR cooler does add extra complications but I can't say what as I've not done it.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
