Black 3.6 V6 Estate
guyblue10
Recommended Posts
...Just added a bit more blackness.....first these http://www.superskoda.com/Skoda/SUPERB-II/Superb-II-painted-headlights-sportive-bottom-eyebrows-in-BLACK-MAGIC-metallic-paint "Bottom Eyebrows"
I think the headlamp washers need plastidipping now.....
....And I've also just tried some of this http://www.flyeyeskit.co.uk/ on the rear lights
It's flexible plastic mesh that just sticks over the lights.  Apparently legal, and I'm sure not everyone's cup of tea....but here we are so far...
  • Like 4
Link to comment
Share on other sites
Is that an R35 GTR in the garage behind?
  • Like 1
Link to comment
What is it with you lot and gold.....
Black Headlamp inserts - Hmmm.... here http://www.superskoda.com/Skoda/SUPERB-II/Superb-II-BLACK-Monte-Carlo-headlights but not xenons and not right hand drive...
Yes, well spotted - GTR behind
The Black and Gold is
THIS   http://www.briskoda.net/forums/topic/218057-brimmas-jps-octavia-updated-to-040514/
Link to comment
Great looking motor you have there. :)
I don't suppose you have the eBay seller for the steering wheel badge do you? I tried putting what you said into eBay but it comes up with no results so wanted to try searching for the seller instead etc....
Dave.
Link to comment
I have a question about your engine. I assume it is the V6 3.6 that is fitted to the R36?    Is this a VR as in the 2.8/3.2 in the MK4 or is it a true "V" ?
 I am thinking about the next stage for my Golf and the R36 engine might be the way forward if it is a VR
Link to comment
The Passat R36 and Superb 3.6 both have the same engine using FSI
http://en.wikipedia.org/wiki/VR6_engine
" a flagship 3.6-litre 191 kW (260 PS; 256 bhp) FSI VR6 engine (a detuned version of that fitted in the Passat R36) complete with4motion four-wheel drive and six-speed Direct-Shift Gearbox (DSG)."
http://en.wikipedia.org/wiki/%C5%A0koda_Superb
This should clear it up, I think it is a VR type?
  • Like 1
Link to comment
Yup, both engines are narrow angle V6's, (15 degree Vee, compared with 60 degree Vee in most V6 engines),  effectively siamesed bores, at 15 degree angle in one block & one cylinder head, with two faces, again at 15 degrees.
DC.
  • Like 1
Link to comment
I am sure the top of the block and bottom of the head are flat surfaces but the bores are at 15' V
I sit corrected....... The combustion chambers must be wedge-shaped?
It's not really a Vee engine at all, probably the same firing order as a straight six, but possibly with staggered crank-pins on the crank-shaft?
I quite fancied a V6, but couldn't find a decent one when searching for an EOS. Gave-up in the end & bought a 2.0 Tsi instead, 250 bhp & 284 ft.lbs after a remap is
similar to the 3.2 VR6.
If I could have found a 3.6 for sale, I might have thought differently.............
DC
Link to comment
DC
Yes I think it has wedge shaped chambers, quite a strange engine really, very compact though for a six cylinder. I also feel its days are numbered, modern turbo four cylinders are as powerful and more economical not to mention environmental advantages.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
