Issues starting when warmed up?
Recommended Posts
Hi Guys I am new to the forum,
 I have an issue where as when I start the car first thing in the morning its first turn of the key every time.
If I get the engine up to temperature then it can turn over a good few times before starting
The car has been plugged in at skoda and a vw specialist with no fault codes.
It only happens when the engine has warmed up? Its not slow at turning over the starter motor and battery are fine
I was told there is a common sensor that fails temp sender or something like that?
Any help appreciated its driving me mad now lol :devil:
Link to comment
Share on other sites
My bet is the battery, regardless of what any garage says.
Apparently with these cars when cold fuel is injected straight away when starting, but when hot a minimum crank speed needs to be met before fuel is supplied. As a battery gets weak it can fall slightly short of this minimum crank speed although not noticeably.
Some have found this to also be a failing starter motor but for cost a battery is the first thing to try.
You could test the theory by trying to jump start the car when warm and see if it makes a difference.
Link to comment
Yup. I'd put my house on it being the battery. I had a similar issue not long after I bought my car. It would start no problem when cold, however after a run and after the engine was warm, the engine would turn over and then make one hell of a rumbling noise before it would cut out. A failing battery manifests itself in many different ways on the Octavia.
I changed the battery and all has been good for the past three years.
Hope this helps & good luck.
Edited by flying pig
Link to comment
I agree with the above. Change the battery and if that fails to cure it then change the starter motor.
A lot of garages misdiagnose this as being a problem with the temperature sensor, as sometimes disconnecting the sensor will allow the engine to hot start more easily . That doesn't mean the temp sensor was faulty, it just means you're fooling the ECU into thinking the engine is cold when it isn't, allowing it to go into cold start mode and ignore the cranking speed.
Link to comment
Iv got the same problem. Changed my battery and still the problem is there.
Iv been told that cause the car is turning over it's not the starter motor.
I am still lost as wat is can be. Do you think it's worth renewing the injector seals.
Thanks sara
Link to comment
Thanks sara
If a garage has told you that take the car to another one who knows what they are talking about! This is a well known problem with VW PD diesels.
The starter motor only needs to be cranking the engine fractionally too slowly for hot starting to become difficult as the ecu won't allow a hot engine to start if the cranking speed is too slow.
The reason cold starting isn't affected is because the ecu ignores the cranking speed when the engine is cold.
Link to comment
I had this on a Merc Sprinter, an injector was leaking off. Have a look at the fuel return pipes (if there's any clear bits) and see if there's any big air bubbles. It was a common problem on the 2.5 cdi engine, worst around 02 - 04 year.
Link to comment
That only applies to common rail engines, the PD system used on these engines is very different and doesn't have injector leak off pipes as such.
Whereas a common rail system has to see a certain fuel rail pressure whilst cranking to start, a PD has to see a certain rpm during cranking to start.
  • Like 1
Link to comment
My dad had this problem on his Golf Plus 1.9 TDI PD 105Bhp. I researched it online and heard all the Cam position Sensor and Temp Sensor remedies. In the end, he got the starter changed. The problem went away and has not re-occurred since. That was a year ago now.
HTH
Link to comment
If you're getting specific fault codes relating to a particular sensor, then fine, replace that sensor. But 99% of the time on these where there are hot starting problems with no fault codes stored, and perfect cold starting, then it's either the battery or starter motor.
Link to comment
My apologies, didn't give a thought to the common rail aspect.
Link to comment
I had this, turned out to be the butterfly valve (Anti Shudder Valve) in the EGR manifold. it was coked up and when it got warm it became sticky. I took it off and gave it a good glean with Mr Muscle and a toothbrush.
Link to comment
PDs are a bit of an oddity really and can suffer with occasional issues that don't affect common rail engines. On the positive side they are immune to quite a few problems that can blight some common rail systems!
Link to comment
So I'v now had my starter motor check my a specialist and it's working fine. He has said it's a diesil problem. So it's going on a vag com tomorrow to see if that can point us in the right direction.
Any other ideas
Cheers sara
Link to comment
Any other ideas
Cheers sara
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
