Need to Replace Front Left Dipped Beam
Recommended Posts
Following the visit to the Skoda in Walmer and after running diagnostics it seems 99% certain that it is the ballast that has packed up. The 1% doubt is that they didn't have time to try out the left headlight (working) ballast as it necessitates removing the bumper. The ballast is underneath the headlight apparently. I will buy the ebay ballast for £85 and get my local independent to fit it next week. As an aside I would recommend Adamsons the Skoda dealer in Walmer, and wish they were my local main dealers.
Link to comment
Share on other sites
Trying the simple option in the morning and going to get a fuse, if that don't work i will put into the garage for testing.
Link to comment
Actually are instructions in the manual and as you describe very simple. However......
There are instructions for normal halogen dipped headlight replacement, but not for the bi-xenon's.
"Note: This Owner's Manual only describes the replacement of bulbs where it is assumed that no major complications will arise. Other light bulbs should be changed by your specialist garage.
Gas discharge bulbs (xenon bulbs) operate with a high voltage, professional knowledge is required - danger to life!"
Although I am still unsure as to what the differences (if any) there are between replacing halogen and xenon headlight bulbs on the Superb. Did you have to remove the ballast to gain access to the D1S bulb?
Link to comment
Whats the ballast  :blush:  :blush: ? All I had to do was open bonnet and take a plastic cap off the back of the headlight unit and twist and that was it done. No harder than changing a household light.
Link to comment
That's good to know then!
It also suggests that Skoda are being some what over cautious when suggesting that xenon bulbs should only be replaced by a main dealer!
On older models it wasn't uncommon to have to first remove the ignitor or ballasts before gaining access to the xenon bulb. It sounds like Skoda have made it far simpler on the MkII Superb.
Link to comment
The ballast is a type of control unit. The ebay listing below is the appropriate unit for my car, and I believe yours as well. The price from a main dealers is around £220 I think.
http://www.ebay.co.uk/itm/271261527672?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Replacing the ballast though does involve removing the front bumper, as it's below the headlight.. This has become rather a expensive exercise although the £135 I spent on the new bulbs does mean I should have lights that are much brighter.
Edited by Knowsley
Link to comment
Right been to the Skoda garage. Not the fuse. Booked in for diagnostics but they wanted £90 up front. Booked now into local garage beside house who will test and let me know. Going in Tuesday.
Link to comment
I was charged £60 inc vat for the diagnostics at the Skoda dealer where I am this weekend. Your local garages diagnostic device may not come up with anything, my local independent garage tried but it didn't reveal anything. They didn't charge me though.
Link to comment
Put it into local garage and ballast had gone. they had ordered one through dealer at over £200. I asked them to stop it and they are allowing me to buy my own and they will fit. Got one via the link above from HIDs for £85. I had bought the bulbs from them last week for £75 so they are happy for me to send them back.
All well should be sorted later in week.
Link to comment
I had the ballast replaced today and now all working fine. The old ballast was full of water so not much wonder it had packed up! I've only had the car for about 6 weeks, so have no idea how or why the rubber cap on the back of the headlight had come adrift, but this being detached obviously let the water in. Altogether quite an expensive exercise. I now have Osram Night Breaker bulbs (£138 for two) which are supposed to be 70% brighter than the originals, which I didn't need, but have decided to keep. My total expenditure including the bulbs was £375, which is probably less than I would have paid for a main dealer to diagnose, and supply and fit a new ballast. I will probably put the old bulbs on eBay and see what I can get for them.
Link to comment
Right all done. Total bill
Local Garage £114 labour and diagnostics and ballast on line £85 = £199
Skoda Price. £96 diagnotics, £200 bulbs and £80 fitting = £376
This sites advice saved me £177 and that the reason I pay my membership.
Thanks everyone for help.  :clap:  :dance:  :rofl:  :beer:  :moon:  :thumbup:  :party:
  • Like 1
Link to comment
  • 1 year later...
Thanks for all the good info.
Just changed my Xenon D1s burners after the left dipped beam failed and it was a simple job!
IMPORTANT First off note the warning in the manual, High voltage possible and danger of death so
  • Engine off
  • keys out
  • ensure the lights are off
  • don't put the keys in your pocket where a press of a button will cause the lights to come on.
  • Ensure you remove the multi-plug that supplies power to the headlight before you remove the rubber cover, details below....
  • If you really want to make sure, disconnect the battery.
I bought a pair of D1s burners (which is what xenon bulbs are generally referred to as) as graded parts which just meant removed from new HID Kits, presumably where someone wanted a different light colour etc for £72 for the pair delivered from http://www.hids-direct.co.uk/2-x-osram-66144-66140-xenarc-d1s-35w-hid-xenon-bulbs-graded/
Look on the net for a 10% discount code.
The job took five-ten minutes to change them on my Skoda Superb II Elegance.
The flesh the process out if it helps anyone.....
Skoda Superb II Headlight - Bulb changing
  • IMPORTANT remove the multi-plug connector next to the rubber cap shown at B above, this will ensure the burner will not become live while you are touching it!
  • Remove the middle large rubber cap (picture showing the layout of these is in the manual under bulb replacement also attached here for reference the cap is labelled B). This is the easiest one to get to!
  • Twist the base of the bulb anticlockwise about 45 degrees and pull the Burner out backwards.
  • Pull the metal wiring connector off the D1s.
  • Mine new burners came without the plastic mounting ring which I removed from the old burner by releasing the small plastic catch, the ring then opens into two halves which easily locate (in two notches on the new burners) and close back into a ring and the latch clicks back together. Don't worry its very obvious when you look at the mounting ring plastic.
  • connect the wiring connector to the new burner (push fit).
  • Carefully insert the new burner in to the headlight in the same 45 degree anticlockwise position the old on came out at and turn clockwise 45 degrees till its locked in place.
  • refit the large rubber cover.
Job done.
Honest its really simple but don't do it if you are not confident you know the power is off first.
Cheers,
Link to comment
HI there guys,
 had left my mk2 superb elegance stood over 3 weeks and when i came back heater blower was stuck which was repaired twice but now works ok (humidity issue just clean and dry) but what worries me is the xenon problem i have. after couple of hours or sometimes even minutes lights out. comes on the middle console as chech the beam. its not the bulb swapped them works ok. quite a bit of water in the lamp. all dried now but light died completely. long bem and side works. just xenon. it doesnt come up as a fault anymore. here is a complete read out if you recognize anything feel free to let me know.
forgot to mention that brand new batter bosch s4 was dead in 3 weeks which caused a lot of these faults
thanks
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BK    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000AG  2848
   Revision: 13H01---    Serial number:
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 6FE7CBFC7E63CD667D9-803A
3 Faults Found:
049493 - No Communication with Instrument Cluster
               U0155 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 220389 km
                    Time Indication: 0
                    Date: 2016.14.23
                    Time: 00:00:07
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Temperature: 14.4°C
                    Voltage: 12.16 V
                    Bin. Bits: 00000000
                    Torque: 93.0 Nm
                    Temperature: 23.4°C
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 195957 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 01:54:04
             Freeze Frame:
                    RPM: 782 /min
                    Speed: 0.0 km/h
                    Temperature: 8.1°C
                    Voltage: 13.53 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 25.2°C
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 050 T    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1812
   Revision: 04844002    Serial number: 00000905060952
   Coding: 0000020
   Shop #: WSC 01357 011 00200
   VCID: 234FF7CCE22B3906A91-8076
2 Faults Found:
18082 - Powertrain Data Bus
            P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 23
                    Mileage: 220389 km
                    Time Indication: 0
                    Date: 2016.14.23
                    Time: 00:00:07
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 23
                    Mileage: 220389 km
                    Time Indication: 0
                    Date: 2016.14.23
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 N    HW: 3T0 907 044 N
   Component: Climatronic   122 0102
   Revision: 00003001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 3D7B21B4AC8F6FF6BF5-8068
2 Faults Found:
9485831 - Air Blower
          B10BE 07 [009] - Mechanical Failure
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 195963 km
                    Date: 2082.14.03
                    Time: 02:53:23
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 195963 km
                    Date: 2082.14.03
                    Time: 02:53:28
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 A    HW: 1K0 937 087 A
   Component: BCM PQ35  H+  020 0358
   Revision: 00020000
   Coding: 48990AB8D841F1C040080084110089A401711BAE632085605C4040000000
   Shop #: WSC 33361 790 00999
   VCID: 2F670BFC7EE38D663D9-807A
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 15070  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 260808 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
4 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 195963 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 02:50:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 99
                    Mileage: 195963 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 02:52:01
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 99
                    Mileage: 195963 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 02:52:01
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 195963 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 02:54:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.60 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 3T0 919 475     HW: 3T0 919 475
   Component: PARKHILFE PLA H07 0002
No fault code found.
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655     HW: 3T0 959 655
   Component: J234__LAJ VW10 HI   1815
   Revision: 17013000    Serial number: 003CCPFPSZN6
   Coding: 0016714
   VCID: FEF966B8A90934EE66F-80ABS
1 fault  Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 220389 km
                    Time Indication: 0
                    Date: 2016.14.23
                    Time: 00:00:07
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001731
   VCID: 76E9FE980139FCAEBEF-8023
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H06 0009
   Coding: 00000130
   Shop #: WSC 00000
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 940 D    HW: 3T2 920 940 D
   Component: KOMBI         H28 0024
   Serial number: 00000000000000
   Coding: 410F00
   Shop #: WSC 00633 978 967808
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 356B399494BFB7B6775-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 0000K088050B1F
   Coding: EDA1FF064006023303
   VCID: 356B39945CBFB7B6775-8060
5 Faults Found:
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 139
                    Mileage: 191233 km
                    Time Indication: 0
                    Date: 2012.14.02
                    Time: 21:54:26
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 122
                    Time Indication: 0
                    Date: 2016.14.23
                    Time: 00:00:07
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 122
                    Time Indication: 0
00381 - Databus Instrument Cluster
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 122
                    Time Indication: 0
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 195957 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 01:54:05
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H28 0024
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: F2E14288ED51608E127-80A7
1 Fault Found:
02344 - Seat Position Memory Store Switch (E447)
            003 - Mechanical Failure
             Freeze Frame:
                    Fault Status: 01100011
                    Fault Priority: 5
                    Reset counter: 99
                    Mileage: 213069 km
                    Time Indication: 0
                    Date: 2015.14.24
                    Time: 18:52:16
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H52 2844
   Revision: AB001001    Serial number: SKZ6Z7L9092187
   Coding: 040004020004008100
   VCID: 2E5916F879E9846E36F-807B
4 Faults Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Reset counter: 99
                    Mileage: 191233 km
                    Time Indication: 0
                    Date: 2012.14.02
                    Time: 21:53:39
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 197556 km
                    Time Indication: 0
                    Date: 2013.14.17
                    Time: 17:18:24
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 14:38:24
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:31
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0190
   Revision:             Serial number: 0000100202240
   Coding: 011D0220DE01121002
   VCID: 40855840D37D021ED43-8015
1 Fault Found:
            000 - - - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 195957 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 01:59:43
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 196    2301
   Revision: 00H15000
   VCID: 2A511AE88501E84EEA7-807F
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 220389 km
                    Time Indication: 0
                    Date: 2016.14.23
                    Time: 00:00:07
             Freeze Frame:
                    Voltage: 12.25 V
                        DD
                    Temperature: 33.0°C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0190
   Revision:             Serial number: 0000100209889
   VCID: 3F875BBCAE837DE6AD9-806A
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 139
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:30
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 0 km
                    Time Indication: 0
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0133
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 346D049057C5AEBE40B-8061
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    S004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    S004
   Coding: 00000021
1 Fault Found:
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 195963 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 02:54:23
             Freeze Frame:
                    Voltage: 13.49 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
4 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 99
                    Mileage: 191233 km
                    Time Indication: 0
                    Date: 2012.14.02
                    Time: 21:53:39
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 197556 km
                    Time Indication: 0
                    Date: 2013.14.17
                    Time: 17:18:24
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 14:38:24
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:31
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0190
   Revision:             Serial number: 0000100204019
   Coding: 010C00200001221002
   VCID: 01039D4498F7CB169BD-8054
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 139
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:30
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0190
   Revision:             Serial number: 0000100193376
   VCID: 55AB99143CFF97B6975-8000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 139
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:30
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 3C8 035 730     HW: 3C8 035 730
   Component: Telefon             2800
   Revision: 00012000    Serial number: 0000000098593
   Coding: 0020121
   VCID: E0C538C033BDE21E743-80B5
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.02
                    Time: 18:30:29
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 195926 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 14:38:24
00992 - Consumption Cut-Off Active
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 138
                    Mileage: 220334 km
                    Time Indication: 0
                    Date: 2016.14.21
                    Time: 19:07:11
End   -----------------------------------------------------------------
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
