Just a Quick One, What VW is The Yeti Based On?
gumdrop
Recommended Posts
I thought the Yeti was based on the Tiguan floor pan and drive train,
but apparently not, so where has it evolved from.
Link to comment
Share on other sites
VW Golf, eh!
Thank you very much gentlemen, if anyone comes up with
a complete list of VW donors to the Yeti that would be interesting.
Link to comment
I seem to recall reading that it has a Polo (Fabia) front sub frame which is why it has a better turning circle than the Tiguan :sun:
Link to comment
The only real downside of the parts bin approach used on the yeti, and it is a big downside, is the unneccesarily poor bootspace, forcing people like me who need as much space as possible to not spec a spare wheel and boot floor. The spare wheel well should be lower but it isn't because they just used the haldex 1k floorpan. Real shame in my opinion.
Link to comment
If the boot floor was lower it would have reduced the ground clearance and the departure angle, both defeating the object of building a part-time off-road vehicle.
Link to comment
Just had a look on mine out of interest and there's a huge amount of wasted space beneath the wheel well where you'd have
on a 4wd model. So it's certainly true to say that it would have been very easy to give 2wd cars more boot space. And I wouldn't mind a bet with a bit more development work something could have been done to improve on the 4wds without compromising ground clearance. Look at it this way - how likely is it that the solution representing path of least resistance and cost, i.e. taking the 1k floor pan unmodified, is the also the best solution?
Edited by Nick P
Link to comment
Simplest answer would have been a bit more rear overhang and longer boot, cf. Fabia Estate, SEAT Altea XL.  Departure Angle would still have been OK, and would have worked for 2WD and 4WD.
Link to comment
900000 will be along soon, but it is based on several vehicles including Polo, Golf, & Tiguan if I remember correctly.
  • Like 1
Link to comment
It's mostly mk5 Golf I believe.
Boot size is fine.
Yeti is 4.2m long (ideal for us) and the boot is bigger and far more useful than a 4m long Fabia or Fiesta.
Those criticising the boot space tend to come from bigger cars (Octavia?) which is understandable to a degree.  But the Octavia is a longer car... which wouldn't fit in our garage.
If you want a bigger boot, I believe you buy a VW Tiguan or something else.
  • Like 4
Link to comment
Boot size is fine.
That says it all really. :thumbup:
Fred
Link to comment
Just to round this off, the Yeti is built on the VAG PQ35 floorplan.  The first cars to be built on this were the Golf V, Audi A3 and Touran in 2003.  In chronological order, by year, it was then:
Toledo, Octavia, Altea, Caddy
Golf+, Jetta, Leon
Eos, S3,  TT
Tiguan
Golf VI, Scirocco
Yeti
Octy Tour, Alhambra, Sharan
Beetle, Golf cabriolet, Leon hybrid, Octy Greenline, Q3, e-Altea XL
Macan, RS Q3
Proposed TTQ
The only reason you'd say it was "based on a Golf" is that the Golf was first, and most common, to use the platform.  You could equally say it is based on an A3 or Touran, or any model that preceded it.  In truth it isn't "based on" those cars, it just shares a common underpinning and some other assemblies.
  • Like 2
Link to comment
Ask 900000 he knows.
I would have just posted the link Nick P posted.
Which I would have thought, explained pretty clearly that a Yeti is a bas£ard child of MANY bits and is NOT based on a singular platform.  And even then a "platform" these days is not as you had had with a Ford Model T, a ladder frame chassis with bits of suspension and an engine hanging from it. All modern cars (bar a few wooden chassis Morgans and most pick-up trucks) have a monocoque chassis WITHIN which you can tinker and fit whatever bits you like. To make lay people understand these things and get the marketing people excited, they call some of these "combinations" of parts a "platform" yes. But that is all just marketing hype. Most cars are made up like a Yeti. From whatever parts suited the purpose best, to make a specific car.
Link to comment
The wood in Morgans isn't the chassis, it's the frame on which the body panels sit. The chassis is metal (IIRC steel in the classic models and aluminium in the Aeros). :)
I stand corrected then! But then I was not born yet for decades when Morgan first started making a chassis that way. So I guess it's ok that I didn't know. :happy:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
