Brake bleeding help !
Recommended Posts
Is there anything different to do when bleeding your brakes up due to ABS?
If your doing a simple bleed no, just use the good old method of pushing the pedal up and down while someone els is opening and closing the bleed nipple. Take care not to push the pedal all the way to the floor.
If the fluid has been completely drained you can trigger the abs pump with diagnostic equipment.
Link to comment
Share on other sites
Much easier to use a pressure bleeder than risk killing the brake master cylinder by using the pedal pushing method. Using the latter if you go to far with the pedal you permanently damage the seals in the cylinder. The VAG approved method is pressure bleed and not pedal pushing.
Link to comment
Pressure bleeder can be as easy as buying a Gunsons Easy Bleeder roughly £20 from Halfords/Screwfix/ and lots of small motor factors. It will last you quite a few years until you can't stop it leaking, then its time for your second one!
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
