Cars dead
Recommended Posts
Hello 'Sxfash'
How many miles since last belt change/ mileage reading now?
Sorry to read about your latest expensive break-down..
It's just hit 155000
Is that the answer to the second question or both in one.
Link to comment
Share on other sites
Is that timing chain come off so pistons will have hit the valves / cylinder head so engine is a right off?
Timing belt.
Bad luck Sxfash :(
Link to comment
Stick a belt on it and see how it runs.
I've rebuilt a couple of these now, most could have been fixed quite cheaply without changing valves. Generally the hydrolic caps smash under the rocker cover... if going some speed/high rpm then more damage is done.
Link to comment
Now why in the hell would you even do this? You need to strip the top end and INSPECT everything, not try and run it smashing more stuff up.
It's an interference engine SOMETHING WILL be damaged, be in no doubt about that.
hutchy, I'm shocked, you should know better than to offer such dumb advice.
  • Like 1
Link to comment
Why? Because it works.
He's already looking for a replacement engine so has nothing to loose. It doesn't make it a perminant solution just the easiest way to go without "stripping and inspecting" as I said I've stripped and inspected a few failed timing belts now and very little damage is usually done on these engines.
It's irrelevant anyway IMO, the op will take it to a garage who will says it's ****ed and will cost a million pound or we can replace the engine for 2 million pound.
Link to comment
Managed to source a head of a mk4 golf asz of devonutopia so going to start taking my head off an having a look at damage already took rocker cover off an one of the lobes on cam is damaged so god knows what rest is like. Absolutely gutted just hope I can fix it
Link to comment
Don't forget you need new stretch bolts to fit your unit injectors to the Golf head, your head is scrap now so it doesn't matter as long as the pistons are ok.
Link to comment
Any tips especially to gt injectors out
Did you get my emails with the attachments?  I thought all this was in there?
You need a puller to get injectors out.
Link to comment
Started taking head off tonight but got stuck one of the nuts that holds the exhaust to the turbo was already rounded off bit it's the most awkward on to get to anyone any ideas
Link to comment
Use a nut splitter.
Link to comment
More expense and I've seen someone do it on youtube but just don't want to damage injectors and you know anyone who's selling a turbo kkk or pd150
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
