Can I use this oil?
Recommended Posts
Iirc the oil spec is 5w30, and has to be equivalent to VAG 507 oil, someone may correct me on this, but that's what I got from TPS for the service I did on my 1.8TSI
Link to comment
Share on other sites
504.00 is the VW spec for petrol engines, if it meets that then yes.
504.00 is for variable service; 502.00 if you're on fixed service i.e. 10,000 miles.
My car's well out of warranty now so I've just cleared the counter in the maxi-dot.  I use 504.00 and have an oil and filter change every 10,000 miles; other items - e.g. pads, plugs - when they're needed.
Servicing is the most almighty rip-off: £200 for "check windscreen wipers", "grease hinges" etc???  The CRUCIAL thing is the oil; other things can be checked when you're in for MOT or tyres e.g. steering, brakes.  Pay careful attention to the noises and feel of the car as you're driving, of course.
Link to comment
This is what I got from TPS
Quantum LongLife III
5W30 Fully Synthetic Engine Oil
5L
Part Number: ZGB115QLB00501
Type: Engine Oil
Specification
Volume: 5L
Industry Standards - ACEA: C3
Manufacturer Specifications Approved: VW 504 00, VW 507 00, BMW Longlife-04
Meets the Specification: MB 229.31 and 229.51
Quantum LongLife III 5W-30 fully synthetic engine oil is formulated to keep engines and exhaust after-treatment devices, especially diesel ...Read more
  • Like 1
Link to comment
The key here is to check the container for the all important VW codes.
As pointed out above VW 504.00 would be ideal.
Edited by silver1011
Link to comment
You need
2.0 PD
505.01 9k change
506       Variable LL
507       Variable LL
2.0 PD DPF
507 Low ash Longlife drop optional
2.0 CR DPF
507
Not all FS oils are suitable, ideally it should say B3 B4 or VW approved on the bottle
The whole thing is about high pressures, a 5/30 is a good oil until it gets to the point where it can't lube a point that is under intense pressure.
Link to comment
Check the OP
It's a Petrol, not a diesel.
( Still off topic, as well as it's lubricating ability, a significant reason for using 507.00 in a modern diesel is its low ash formulation to reduce clogging of the DPF)
  • Like 1
Link to comment
Check the OP
Indeed, good spot.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
