ko4 turbo upgrade advice and help needed please
Recommended Posts
Hi guys,
I'm looking at upgrading to ko4 turbo and need to know 2 things..
1 - what parts do I need?
From what I can make out so far I need ko4 turbo, manifold, downpipe, 3' maf (is this cupra r, s3, tt mad??),
And then the obvious mapping at the end.
And secondly - what modifications if any are needed to make this happen?
Thanks in advance
Ant
Link to comment
Share on other sites
Look for a company called beach buggy turbos, they do a ko3s hybrid which is capable of about 350 maybe more. They havnt been able to fully test how much power one of these can make yet
Link to comment
You need
Turbo
Turbo lines
Down pipe
Maf
Tip
Injectors
Mannifold
Top turbo to intercooler pipe
Turbo bracket
You will also need a bung to put in the egt port as we don't have that
Mapping
You will see a true 260 to 270
More if you run a high flow manni etc
Actually not that cheap when you consider you will also need
Gaskets
Oil oil filter
Coolant washer possible banjo bolts
Mannifold to turbo bolts
Link to comment
I would be happy with 260-270.. 280 would be nice! :)
I'm having my intercooler pipes made up custom by my mate in stainless (he works for custom exhaust place)..
Any modifications needed to bolt it up?
Anything in the way I would need to move or bend ect?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
