Towing Electrics
Recommended Posts
Thanks for your replies. Was hoping to ger a part number for a loom. don't like scotch locks. Are any of the other models interchangable with the plug in looms? Also its a March 2007 so towards the end of the mark1's. Was a demo first so guess was still up to date! Do they need any coding?
Mark
Link to comment
Share on other sites
I don't like Scotch locks either, but a bit of a tip - it's possible to use crimps and fitt wo wires into one end and single into other. Maplin do heat shrunk crimps ,but if in doubt , you can always add a bit of heatshrink before the crimps and once the crimp HS is shrink and cool, slide othr over wires and shrink . ( slide two wires into HS, and slide well down. strip two wires and add to crimp. Make crimp off on both sides,and heat. slide extra down to cover wire entrance and heat. )
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
