Adjust speed readings according to tire size
Recommended Posts
Hello all,
I am thining about changing my 14 inches standard wheels - 185/ 60, to a set of alloys, 15''. Due to the fact I like a more comfy ride, I will not fit the recommended ones - 195/50, but I will get something about 195/60 or somewhere around. Will it be possible to adjust the instrument panel according to the new tires, so my speed, mpg and everything else will keep recording correct data?
I found this and this, but I am not sure...
Have anyone tried this before?
Link to comment
Share on other sites
I've gone up a profile size on my 16"s - a 3.4% increase in overall diameter, and my speedo now reads about spot on.
Tyre calculators suggest that going to 195/60/15 instead of 185/60/14 is an increase of 6.4% overall diameter.  So will read a little slower than you are actually going, but useable.
As for 'real' mpg figures from the dash, that's a debated topic in itself! (I find mine to be +/- 5 to 10% out).  Hopefully someone who knows VCDS can help to answer if correctios can be applied in VCDS..
Link to comment
Just to give you the heads up, They will rub on the rear arch and touch the pointless bit of metal that sticks out behind the liner - I used an angle grinder to remove the metal lip and no more scrapey noises! :) speedo reads spot on with sat nav too!
  • Like 1
Link to comment
If the manual says that I should fit 195/50 tires on 15'' wheels, will I break anything if I will go with 195/60 ? I am talking about the drive shafts, wheel alignment - angles - that will have to be reworked and all the suspension components also. I'm driving about 6000-6500miles/year, 80% the city.
Edited by Alexandru
Link to comment
There will be additional strain on the components due to the larger torque needed for the larger wheels. I doubt you'll break anything, but I've driven a car on oversized wheels and it was sluggish. It was much better when back to standard. Your insurer may not like the change either.
Link to comment
If that's what the manual say I would imagine that's what you should do, it just makes scene to lower the profile of your tyre if your increasing the size of your wheel or lowering the car,
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
