Pics with spacers fitted
Recommended Posts
Hi all, thinking of getting some spa ers for the octy, prob 15mm front 20mm rears, anybody running this set up, any probs?
Or what are you running? Supporting pics appreciated
Thanks in advance
Link to comment
Share on other sites
I had 12 mm on the rear and then put my coilovers on and the tyres were catching on the arches over bumps. So I changed them for some 6mm and it sits perfect now. No catching or scrubbing :)
Link to comment
Was this on standard 17" spiders with 205 tyres?
Link to comment
Wheres best place to vet spacers? Ivr been thinking abiut this also
vet spacers or get spacers........ :D
The answer is so wide buddy you can get them anywhere.
Any performance shop and some of the ones on this site on home page.
Then the question is how wide you want to go and that depends on what wheels you have.
H&R are probably the best company. just make sure that if you get spacers they are hubcentric ones
something like this
http://www.ebay.co.uk/itm/15mm-Hubcentric-Spacers-for-Skoda-Octavia-2004-09-Alloy-Wheels-Pair-Bolts-/171231565980?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item27de32589c
to the OP 15mm on front and 20mm on rear is only ok if you have not lowered car else you will get tyre rubbing with std wheels and offset.
I have 8mm on front and 12mm on rear as my car is quite low.
  • Like 1
Link to comment
Any performance shop and some of the ones on this site on hoe page.
H&R are probably the best company. just make sure that is you get spacers they are hubcentric ones
something like this
Thanks mate, found a few images on google but mostly have different wheels so makes it hard to tell, im only 35mm low so actually only 20mm lower than standard but thinking of getting the fk top mounts to lower front by another 10mm so might go with 10mm front and 12 rear as ive seen a pic with 15mm rear and seems the tyre slightly pertrudes the arches
Link to comment
15mm at rear will not protrude arches. Again it depends on offset of your wheel to weather the wheels are sticking in or out of arches. If you are looking at none std wheel the offset could be something like 45mm yet the std wheel has a offset of something like 38mm
Link to comment
Would just be standard offset as im keeping the spiders
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
