Few questions about 1.9 tdi mk2
Recommended Posts
well i only had a 15 amp tryed that and it worked however took it out now and will get a 20 tomorrow and smack it in
find it so stupid that there is a paper there telling  you what fuse is where and it doesn't say what fuse should be in there -_-
 should be 25 amp for the rear window heater
Link to comment
Share on other sites
Car got serviced today but kind of annoyed the mechanic didnt use the STP engine flush, however swapped the flush for some injector cleaner,
New sump fitted oil an air filter dun aswell,
Need to put the under tray on aswell
Link to comment
1st of all i used a volkswagen specialist, he didnt put the tray back on because it wasent on in the 1st place, he chucked it in for free as he had one on the side
2nd yes i know its is a 10year old car however it was not a incompetent mechanic because if you look on the forum it is a common fault with this model
and it was just something i said i wouldnt of bought the car if i didnt know history behind it
And i have a 1.9 pd 105
I mentioned the 2.0tdi because of the common faults onit if u read carefully :)
Link to comment
And i didnt say it is very bad, i said that these new ENGINES are worser compared to the old engine from mk4 golf personal opinion everyones entitled to 1 are they not?
And i also said the 2.0 tdi being the worst engine as they have the injector problems i heard about and some with the electric hand brake an so on
Sorry if i offended you it was not intentional mate
Link to comment
I have a 2.0tdi and have now serviced it myself 3 times draining the oil through the sump drain and putting in a new sump plug, all without cross threading anything. I guess my car is one that just isn't susceptible to these common issues.
  • Like 1
Link to comment
Injector problems = PD170 on vRS models, and as Mike said, replaced for free.
Any idiot can cross thread a sump plug on any make car, probably due to not using a new one each time as you are supposed to.
No electric handbrakes on Skodas.
The 1.9PD is a bulletproof engine as long as you service it correctly, with the correct oil. Did you replace the fuel filter at this service as well, worth doing at each service for the £10 they cost.
Has anyone given you the bad news about DMFs yet LOL
Link to comment
Yep, the filter gets black from soot getting in to the fuel as a result of the PD engine design. Changing the fuel filter regularly is a no brainer really. I did mine on the PD140 at every service, and at 180k it was still going strong.
Don't succumb to variable servicing, stick to every 12mth or 10k, clean oil is essential for the longevity of the PD engines.
Link to comment
Hmm i think ill get the fuel filter changed and will definatly look in at the brakes as car has been standing alot in its life
Regarding fuel i always use shell v power regardless of make or model, just for peice of mind
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
