Steering Wobble Under Gentle Braking
Recommended Posts
As above, over the last week I have started to notice wheel wobble under gentle to moderate braking. Rather strangely it does not happen under heavy braking and only happens at speeds below 60mph.
Is this likely to be caused by warped brakes or something else?
The car has recently had:
New wishbones and bushes
New N/S Wheel Bearing
New Front ARB Bushes
In the last 3 to 6 months:
New Coilover Suspension
New Droplinks
New Top Mounts
Also the brakes that I currently have on are less than 12 months old.
Any ideas would be appreciated.
Link to comment
Share on other sites
Mine always does this.  I believe that it's the discs.  When they were brand spanky new it didn't do it, now it does.
Did the same with the previous discs too!  I have a habit of buying poor discs, or bad driving, not sure.
Link to comment
Try some enthusiastic braking, say 6 times stop 60 to 20 as hard as you can. I'm pretty gentle on the brakes and used to get a build up of crap on the discs which cause a wobble like you describe and such treatment would sort it.
Link to comment
Thanks for the comments guys. At time of changing the discs and pads last I was a bit strapped for cash and bought Drivetec discs with Mintex pads from my local CES. I will try giving them a clean up and see wot happens.
Just find it a bit steange that it only happens at lower speeds and more gentle braking. If it comes to it I'll just change the brakes for OEM.
Link to comment
Link to comment
are the pads seated properly? might be a tad loose in the carrier, so at low speed gentle braking you can feel the wobble.
heavier braking is pushing the pad in fully and holding it solid...
Link to comment
So its not juddering braking from say 60mph? If the discs are warped it should actually be worse at higher speeds.
Yes thats right. No vibration from higher speeds with either light, moderate or heavy braking.
I will have the wheels off this weekend (weather permitting) and take a look
Link to comment
Interesting, this.
I recently (about a month ago) had a reputable specialist put new discs & pads on mine. Initially the car felt great and would stand on its nose when braking. I have just got back from a 2 week holiday touring through France, 4-up, camping gear and roof box on board and the discs appear to have warped already: 2,000 miles.
I will admit that the discs & pads are Mintex and the specialist fitting them did suck his teeth when I told him that, but even so - 2,000 miles seems very low to have warped a large vented disc (312mm) without especially hard use, ie not track work. I am not as hard on brakes as the chap in the Corsa on the M1 yesterday who braked every 10 seconds, whether he needed to or not, because I read the road ahead and I was carrying my young family. My old Audi A6 did the same trip twice on one set of discs & pads and the brakes still felt strong.
Is it just the fact that I chose Mintex or am I missing something?
Link to comment
I got Pagids for my Octy, about 8 months ago - 8k up on them and still all good...
Got them as they were relatively well priced and very recommended around here.
Link to comment
Im going to get a few things checked out in more detail this week. I have also noticed that sometimes when turning fairly sharpish corners I get some wobble through the steering there too. Im starting to wonder whether it's possibly an out of shape tyre? Going to get the brakes properly checked out too with a view to replacing if need be with Pagids and Ferodo.
Link to comment
It's possible. But out of all the tyres I have bought in my life (and it is a LOT - especially when I was racing motorbikes!) I've only ever had out of shape tyres twice.
Once, a front tyre fitted to a motorbike had a bulge right in the middle of the tread. As soon as I rode it, it felt like I was going over a bump in the road every two metres!
And once on a car, I was talked into buying some 'non mainstream branded' tyres, after the bloke explained how they're made in the Pirelli factory but sold cheaper with a different brand name. Well, I was young and stupid! But one of the tyres was also out of shape, resulting in some very similar behaviour to what you have explained. Once I went back and he replaced the offending tyre, all was well.
So it can happen...but it is unusual.
Link to comment
is that a PC way of saying cheap 5hit ditch finders?
Yep. They were solid plastic, slip-matic, traction-less tastic, ditch-finding, hedge-seeking death tyres from hell. I have, and only will, make that mistake once, and only once.
The fact of the matter is, high-quality branded tyres are the way to go. Cheap tyres are a false economy.
I've run nothing else but Michelin Pilot Sports on all my cars for years now. Fortunately I have a mate at a tyre fitters who does me a set of PS3's on my Octy for £400 fitted.
I NEVER get ANY problems. They're perfect, behave predictably, give prodigious grip in wet and dry, are quiet, and best of all, last very well.
Also, strangely - yes, I admit that some monster bit of roadway detritis would puncture ANY tyre, but....since using these Michelins, I have never suffered another puncture either. A weird co-incidence? Or proof of superior construction? Who knows!
Link to comment
well now you jinxed it....
I've been using Cooper Zeons for the last couple of yrs and find pretty decent all yr tyres and good price...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
