preventative maintenance
rv125
Recommended Posts
Greetings everybody I am the proud new owner of a 2006 2.5 diesel superb I've only had it a week bought it from an old man with no mot, one owner from new 40,000 miles genuine.Went straight through the MOT with two advisories on brake pads
Spent some time reading the forum and have already done the following
removed and resealed the plenum chamber Removed the rubber grommets Under the battery tray and brake servo
Fitted new outer CV boots both sides
removed the front suspension top bolts greased them well
the car appears to be dry everywhere inside I must be lucky
Is there any other immediate preventative maintenance I can do the MOT tester said I needed to replace the back brake pads in the next thousand miles do I need a special tool to do this. Apologies if these have been mentioned elsewhere but I'm still finding my way round
thank you
Clive
  • Like 1
Link to comment
Share on other sites
Hi Clive, welcome,
The rear brake caliper pistons have to be wound back, ideally with an appropriate tool. I got a set similar to this a few years ago, and it includes both left and right handed thread wind back tools and adapters for most cars:
http://www.ebay.co.uk/itm/BRAKE-PISTON-REWIND-CALIPER-WIND-BACK-TOOL-KIT-22-PCS-21PCS-34PCS-/251057931956?pt=UK_Hand_Tools_Equipment&hash=item3a743806b4
Have a browse on eBay etc, the above is just the first one I spotted.
The Superb rear brakes need a right hand threaded tool from memory.
0wl
  • Like 1
Link to comment
You removed the plenum chamber????? That seems a bit excessive  :giggle:
Hello Clive - sounds like a good buy.
Gaz
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
