EPC and ABS warning lights
naga
Recommended Posts
Dear Briskodians,
I have a 2002 1.4 Fabia Elegance and my Engine Management light has been on for a while. Showed it to an independent garage and they said it was down to faulty sensor and I ignored it.
About a week ago, ABS warning light went off and it would go away despite multiple erases using my ODB2 VAG port scanner. The fault codes are - 00526 and 00301.
And yesterday, to my surprise EPC warning light also went off. I have read some horror stories like power being cut off, etc., Nothing like that happened with mine, but my Cruise control wouldn't work anymore :-(. Can someone tell me if this is a serious issue or not?
Kind regards,
Naga
Link to comment
Share on other sites
Thanks for your response. Yes, I have a fused brake light and shows up on the dashboard too, but I have ignored it for a while now.
Do you really think EPC and ABS warnings are a resultant of that??
Many thanks,
Naga
Link to comment
Thank you very much, bought 2 new brake lights from ECP for 60p and replaced my fused bulbs. Brake light warning disappeared from the dashboard, but EPC was still on. So, I erased it with the ODB2 tool and after a restart, it hasn't come back. Cruise control is working as normal.
However, the ABS warnings still persist. Do you think it is a different all together? Thanks again for your advice.
Information from this post also helped - http://www.briskoda.net/forums/topic/184142-top-brake-light-works-side-dont-vag-error-16955/
Kind regards,
Naga
Link to comment
I think you are right! Opened the over the battery fuse box and it looks like Fuse 6 is broken. Hopefully the warning light goes away after replacing it. Fuse4 looks like a spare 40A one, will try and use it. Picture attached for other Briskodians.
These posts also helped - http://www.briskoda.net/forums/topic/119972-00301-abs-return-flow-pump-v39/
http://wiki.ross-tech.com/wiki/index.php/00301
Will give an update after replacing it.
Thanks again.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
