oil pressure warning light and loss of power skoda superb
Recommended Posts
Hi all i have a Skoda Superb 2007 plate ,today when i went to the shops the beeper went and the stop motor ,oil pressure warning sign came on read manual , i drove about another mile and    my  skoda started losing power wouldnt go above 25 MPH  i had to get green flag to take me home as i was afraid of doing damage to the engine the green man said it was probably an oil pump problem, i phoned the local garage up and i was quoted £1,678 for replacement ,any advice would be   helpful
Link to comment
Share on other sites
Oil pump and turbo renewal me thinks sadly for you. My sons car, same year as yours did it last year. It cost £1400 using a specialist VW locally. Add another £400 ish for a main dealer.
You may be lucky and the turbo will be ok but again sadly I doubt it.
Edited by Danny 57
Link to comment
ok thanks for that .seems the same problem with audis a4s and vw same engine i think
Link to comment
Unfortunately you bought the one engine in the range that has a major issue. I'm sure others on here can describe the issue better, but in summary as I understand it the oil pump on your engine is driven via a hex shaft / drive that rounds off leading to the oil pump no longer turning and a destroyed engine.
If you try searching this forum you should find other examples of your issue and potential options as to how to proceed. Try searching for oil pump or balance shaft
Link to comment
is it possible to swap the faulty engine for the one that doesnt have problems or does that cause the engine management system to be inoperative ?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
