DRL via low beam
Recommended Posts
I've an octavia a5 fl. It has no fog light. I decided to activate DRL via low beam. I pluged in my VCDS and I realised that this feature is already on. I played with settings (long codig)and evrytime I have no DRL's. Should I enter Security Access code for block 09 or not. Unfortunatly I've no auto scan files to show. The chineese cable is working (activated auto-locking). It Adaptation i've nothing about DRL.
Sorry for my English.
Link to comment
Share on other sites
Fake cable ?  :wall:
Yes, Cable is fake(CAN+HEX-COM->USB  :notme:  (Magic FTDI chip )). But It worked. Before starting an engine, (key position - ACC), hold High Beam and turn right until car beeps. After that DRLs are activated. But if you have Maxidot - you can do it in menu.
Link to comment
You just need to go in via long coding:
  • Select Control Module - Cent Elec 09
  • With the controller open select Coding 07
  • From this screen you'll need to select Long Coding Helper
  • We have to change Byte 23, Bit 2 and Bit 3-4. Bit 2 simply requires a tick in the check box and Bit 3-4 is a drop down list where you should select 08 Turn Lights via Fog Lights
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
