front dash display sometimes fails to work.
Recommended Posts
1 out of every 10 times or so the small square display which shows your details like mpg, gear, temp etc fails to come on.
bad connection or is there one specific fuse for this that may have a damp connection? does tend to happen on more damp days.
anyone had the same issue?
Link to comment
Share on other sites
Sounds like it could be similar to the dry joint issues around the voltage regulator on the PCB dash which cause the similar problems,  Once the dash doesn't work as expected do you find the mpg avg for the last 1000 miles to be reset, etc?
Link to comment
I'm not sure actually. Have to see that next time.
Thanks for the tip.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
