Audio muting on Columbus unit when reversing
Recommended Posts
Hi,
I recently had the Columbus unit in my '09 Superb replaced (under warranty by good dealer) after it failed 2 months after I bought the car. Now this may just be my memory given that I hadn't had the car that long before it was replaced, but the new unit mutes the audio (regardless of source) when you engage reverse and I'n sure the old unit never did that.
It's quite annoying and not really necessary as the parking sensor beeps are loud enough to be heard over whatever you are listening to. Is there a setting that will disable this feature?
I've looked through menus, etc. but can't find anything.
Thanks,
David
Link to comment
Share on other sites
It is in the tone menu.. PDC
This can be changed in the Columbus menu
TONE mode
Tone settings
PDC: Reduce audio vol. - Setting the reduction of the volume when the park distance
control is active
Off - switches off
Low - weak reduction
Medium - medium input sensitivity
High - strong reduction
  • Like 1
Link to comment
I've found it rather fickle.
Mine is set to mute as much as it can but some days/weeks it does and some it doesn't.
Can't find any reason why it would or wouldn't, but there you go.
It is in the 'Tone' menu as above.
Link to comment
TONE mode
Tone settings
control is active
Off - switches off
Cheers, Stu. I'll give that a go.
  • Like 1
Link to comment
Have to agree with you there. I have it set up ok in the menus but it can be hit and miss at times. One thing I do notice is that after a service or work done at the dealers, settings such as this have to be reset sometimes
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
