Hill Hold Control Activated via VCDS?
DarrellGB
Recommended Posts
  • 1 year later...
Hi again, Darrel :)
Yes it is possible on Yeti also. But your Yeti needs to have tilt sensor. If you have offroad button, then you have sensor.
Here is link how to do it:
http://www.myturbodiesel.com/wiki/hill-hold-activation-and-disable-with-vcds-mk6-vw/
Brilliant, thank you :)
  • Like 2
Link to comment
Share on other sites
  • 3 years later...
Assuming the abs module supports HHC, you just need to change the coding. If I remember correctly, it's in byte 16 with a obvious description.
Post a full autoscan of you'd like me to check what the abs module supports.
Link to comment
HHC has nothing to do with the off road button or adaptive HID lighting.
It just needs an ABS pump with a longitudinal acceleration sensor (G251) built in. There is a list that covers most MK60EC1 pumps here: https://www.briskoda.net/forums/topic/298368-hill-hold-control/?do=findComment&comment=3551764
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
