Fabia vrs - catch cans
Lloyd55vrs
Recommended Posts
Guys, has anyone got pics of where they mounted their
Saikou michi oil catch can
I can think who i sent them too, so thought id pop a pic request up
Cheers dudes
Ps- if any of the said dudes are at coombe on sat so can grab more pics :)
Link to comment
Share on other sites
Not much room spare tbh under tge Fabia bonnet, obv engine cover is missing.you might be able to fit one back on with modding it but I prefer it without tbh.
Another pain is the outlet on turbo intake pipe is 21mm, so I've had a 19mm alloy outlet welded on so now I run 19mm pipe on the complete set up rather than a set up with reducers etc :)
Also I've made a bracket so the can is attached to engine, rather than the front panel where I originally fitted it, as it kept breaking the bracket with the engine movement.
  • Like 1
Link to comment
Is the outlet on the turbo pipe a actual outlet ( that can slide pipe onto with a clamp
Yeah its a plastic pipe that is pushed into intake pipe held in place by a big rubber grommet, so yeah you can slide a pipe on it the same as the standard pioe does.
I'm near wales yeah :)
My m8 runs a welding/alloy fabrication business ;)
Link to comment
like the look of this best 1 i've seen tbh what did you fit bracket to? any pictures of bracket?
Link to comment
Posted Yesterday, 23:11
Still not fitted mine, Lloyd  :bandit:
Neither have i.  ;)
Mine's fitted into the corner of the garage quite nicely ,don't want to lose the engine cover really so its a work in very little progress :D
Link to comment
Ah ****,saw your car but didn't see you.
Mine was parked with bonnet up cooling off after both track sessions though :)
Ok.... Seems i failed can hunting at coombe
Coskev could u sort some detailed pics of new mount position etc
Cheers dude
Also... What fabia do u have ?
Was nosing about at coombe
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
