Fabia vrs - catch cans
Lloyd55vrs
Recommended Posts
So is it 19mm from the engine
21mm to the tip ?
yeah.
easy from eng to can, as can has 19mm outlets :)
Just need some sort of reducer in the pipe from can to intake pipe to take it from 19mm to 21mm.
Link to comment
Share on other sites
Sizes go (internal diameter) 16mm - 19mm - 22mm.
Not saying it's impossible to get inbetween but regards to be readily availible that's what most places will stock.
I've also tried both on my rocker cover breather and still opted for 19mm as a tight fit.
Link to comment
do you need any reducers with the 19mm hose? or is it just a case of 2x 19mm hose lengths and away you go?
No reducers needed, just a blank on the turbo intake pipe if venting to atmosphere.
So if i get fabia can with 21/22mm outlets :)
That will be the best then
I guess so, yeah.
Link to comment
Downside to using the bigger hose is its hard to route easily without kinking, and the lack of space over the cam cover/past the oil filler, see my pic.
19mm dipped in some hot water before fitting goes on the cam cover outlet nicely,ignore Alex, as to quote Danham, Alex is a 'little weasel'!!!!!!  :D
  • Like 1
Link to comment
I am a fine specimen of a human being (apart from the lack of hair...) thank you very much Kevin!!  :nerd:  :strong:  :makeup:
Nah 19mm is probably best to be honest. As Kev says, 22mm hose is getting really thick.
I did dip mine in hot water also, but still have troubles pushing it on - my feet were literally sliding on the floor I was pushing on it so bloody hard!!
Oh, and Kev has a zimmer, plus Dan is fat....  :D  :angel:  :clap:  :yes:
  • Like 1
Link to comment
Pics below,it was only a bracket I knocked up quickly due to the original one fixed to the front panel snapping due to the engine movement,was planning on making a proper one,but that was a few months ago now! :)
IIRC I had to bend the bracket on the engine to get it to the angle in pics,its the bracket that engine cover fits too.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
