What could cause overboost fault code
AaronD95
Recommended Posts
He I have recently fixed all my boost leaks nut now if I boot my car is goes into limp mode but if I flick the ignition on and off it will be fine. But the eml light will stay on for a certain amount of miles/time then if I put my foot down at low revs it will switch the light off.
I plugged my iobd 2 into the car and it came back with this being stored on the ecu 78414affe497e223059a350d7ce79991.jpg
Link to comment
Share on other sites
Possible causes for this code are:
  • wiring open circuit
  • wastegate regulating valve
Before you start check all the fuses for engine systems and clear the code and see if it returns.
Are there any other codes?
Good luck.
SN
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
