Temperature control not working
RobLarby
Recommended Posts
Long story short, i had the temperature controls out to change the smds over to blue ones and after fitting it back in, the temperature control no longer works at all.
It seems to be on hot most of the time but it does change on its own sometimes  :thumbdown:
Link to comment
Share on other sites
I cant remember if the MK1 Fabia was an electronic control system or mechanical linkages, if its electronic I would disconnect the connectors again and check that none of the pins are bent and reconnect, if its still the same it could be the flap motors require recalibration and that needs VCDS. If mechanical check that all the cables are routed correctly and attached to the dial properly.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
