Octavia MK2 VCDS Engine Warning
Recommended Posts
Hi,
Everytime I read my Octavia MK 2 1.9 TDi PreFL I get the following error in VCVDS when I do a full scan,
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBBS21Zxxxxxxxxx   Mileage: 114990km-71451miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 AG    HW: 028 101 165 8
   Component: R4 1,9L EDC G000SG  5897
   Revision: 12345678    Serial number: SKZ7Z0D2464107
   Coding: 0000071
   Shop #: WSC 12345 567 06864
   VCID: 68DA34075BC7227B69-803D
5 Faults Found:
18263 - Powertrain Data Bus
            P1855 - 000 - Software Version Monitoring
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
                    (no units): 1.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 126 /min
                    Torque: 148.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.18 V
                    Bin. Bits: 00101100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 126 /min
                    Torque: 148.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.18 V
                    Bin. Bits: 00101100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 126 /min
                    Torque: 148.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.18 V
                    Bin. Bits: 00101100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 126 /min
                    Torque: 148.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.18 V
                    Bin. Bits: 00101100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
Readiness: 0 0 0 0 0
Can someone tell me what this means and should I be worried. My dealer says to ignore it as VCDS is not an official VAG diagnostic system and can't diagnose everything correctly.
Thanks,
John
Link to comment
Share on other sites
The first, I think is just to be ignored. Possibly if the battery has been disconnected.
The second is clearly a problem with the glow plug circuit.
Do you know that the glow plugs are working correctly?
Phil
Link to comment
Hi Phil.
Car starts OK everytime. First turn when cold. When car is warm it sometimes needs two turns.
Car done 78k and has shown that fault since I first got my Hex+Can at 41k
Would just like to know how to get rid of the warning. If I clear it it just comes back.
John
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
