Fabia Vrs knocking over humps! Noise is from the back
Vrs9
Recommended Posts
i.e. when it's parked in MaccyD's surrounded by pimply mouthbreathers in dodgy sportswear, amirite? :sun:
Pretty much! Back on standard stuff for me. Couldn't stand the JOMs.
Link to comment
Share on other sites
JOMs have blue springs.
At the other end of the spring there is a rubber cup that sits between the spring and the body,make sure that is in good condition.
Also check the dampers for any fluid leaks,if both of these parts are in good nick then you can probably rule out the suspension being the cause of the noise.
Link to comment
Are you on about the rear axle bush? If yes then its been changed to a uprated poly bush
Pastie is referring to a rubber ring that sits between the spring and the perch (and is notably absent in your photo).
Earlier, I was referring to exhaust mounts, some of which are also rubber rings.
Link to comment
The rubber insulator goes at the top of the spring not the bottom.
Link to comment
This 1 looks in good nick to me.... Tried chngn axle bushes b4 mekanic sed old 1z r fine as they are uprted already wer can i find the strut mouts?
Dude, a picture says a thousand words, which is probably just as well in your case. What exactly are you trying to ask us?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
