Lowered Mk1 fabia
FrodoJay
Recommended Posts
Hi all, i lowered my Mk1 fabia a few weeks back, and all of a sudden, my driver side drive shaft has started to rub on my anti roll bar. I've raised up the front a bit more as to see if it would work but it hasnt fixed it. is there anything i can do to rectify this as cheaply as possible?
cheers in advance :D
Link to comment
Share on other sites
ive got a set of JOM coilovers. I had to put shorter links on, but would i have to put even shorter ones on?
Nope, you just need to fit a decent suspension kit, AP seems to be the minimum accepted standard. JOM is no good.  :p
Link to comment
I have JOMs fitted on the lowest settng with helper springs in,i had to cut 50mm out of my standard droplinks and weld back together in a sleeve,theres lots of clearance now.
Link to comment
Stop messing about put the correct kit on, forget lowering car.. (only my opinion)?
+1
Was there a vast improvement of the handling by lowering it by the way?
Could it be that it is too low ?
JRJG
Link to comment
  • 2 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
