Octavia Vrs 2006 knocking noise
Recommended Posts
Hey there. I'm new on here and was wondering if you guys could help me.
I have a 56 plate Vrs and from the rear I keep getting a knocking noise every time I go over a speed bump. Iv had my mechanic check it out a couple of times and he can see nothing wrong.
Has anyone else ever had this problem ? Is it at all common ?
Thanks, Scott.
Link to comment
Share on other sites
I had the same symptoms with nothing obviously sha... worn.
Turned out to be a knackered shock absorber, it still damped but had an intermittent 10mm play on its stroke which manifested itself as a loud knock over bumps.
Only found it out by disconnecting the lower end of the shock from the hub and working it up and down energetically.
Fortunately a new pair of OE Monroe shocks were £40 from mister-auto.
Link to comment
Just come across this thread when searching. Im getting a simular noise. Ordered some koni strt shocks to hopefully solve the problem
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
