Putting vRS seats (without side bags) into an Elegance (with)
Recommended Posts
Has anyone done this before and know how to avoid airbag warning lights or worse !?
I've searched but can only see (various) advice on disconnecting plugs while you are swapping, but nothing about what the car does when the seats suddenly aren't plugged into the airbags connectors any more ?
My Elegance 4x4 seats are knackered and the vRS ones I've got aren't !
Link to comment
Share on other sites
In terms of the light being on as far as I can make out its only a case of fooling the sensor into thinking it's pluged in, it might just be a case of joining the connectors so it makes a circuit but it may need to sense a resistance? I would try if you can getting hold of of a seat side connector from a scrappy and joining the wires (think there are just 2) to see if this extinguishes the light before you mess around with the seats??
Link to comment
OK - so I added a 2.2 ohm resistor between the green and white on the drivers seat and the blue and white on the passinger seat - cleared the faults using vcds lite, and the light is gone :)
No multiple flashing airbag light - just stays on for a brief period as normal, and then turns off.
Happy days!
Edited by sebring
Link to comment
Excellent!
Would you mind telling me the sequence you followed when removing & fitting the seats  (re the battery and unplugging airbags) and was it the official part (1JO... part number) you bought or from somewhere else ?
Thanks - glad it worked out
Link to comment
i didn't do anything special to be fair - battery remained plugged in, but the car was switched off without the key in the ignition.
To remove the seats, remove the slider covers (i screwed a small screw into the cover and pulled it off - yes, it makes a small round hole, but i thought that was better then screw driver scratches and dents around the cover. - in hindsight, using a gluegun would have worked.  After the covers are removed, side the seat forwards and raise it to its highest point, and disconnect the plug - then slide the seat back and undo the 2x 13mm nuts - the seat can then be slid out from the rear and removed from the front door.
If you have the resistors, then install them as my previous post and if all goes well, you might not even need to use the vcds to clear any codes.
the resistors i used are from here (note that the purchase price is for 1, and its an extra £1 postage)
http://www.ebay.co.uk/itm/2-2-OHMS-SRS-AIRBAG-RESISTORS-0-25W-2-AMP-FUSE-BYPASS-DELETE-FAULT-LIGHT-/261610592062?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ce934d73e
you might get away with cheaper ones from maplins, but i didn't have time to go searching - and would have cost me however much i save in fuel and time anyway!
Link to comment
Happy days!
I used same method to fit a none airbag steering wheel.
You have to fit a resistor and then program VCDS to either clear the faullt and or disable then re enable .
If you disable you will get fault light on all the time so it is a case of keeping airbags enabled but deal with the resistor to act like the airbags are still there.
some folks are lucky and the removal of airbags seat's and or steering wheel  then fitting resistor does not trigger a fault , but i have never been that lucky :dull:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
