Octy brakes vs the zaf
Recommended Posts
Hmmm........
Guys, with my octy it does stop well, but....
The zaf u seem to tap the brakes and it will happily introduce u to the dash or steering wheel
Its all oem spec stuff on the zaf
The octy is bloody ds2500 pads and those piranha grooved n dimpled discs, front and back
Do u think the instant bite on the zaf is due to the basic pads, and with the octy its pads that like heat?
As im sure when its had a toasting it goood
On a dry clear day i shall try this more lol
As what makes the most diffetence with braking , the pad or disc ?
Pesky zaf :p
Maybe i will go do some experiments , and also check speeds
But im sure the zaf is more instant
Tap = anchors
Link to comment
Share on other sites
Probably mostly due to the amount of servo assistance, but also that DS2500s have more bite with a bit of heat in them.
From the sounds of it standard pads might be better suited to you than DS2500s.
Edit: the pad makes more difference to braking. On these cars drilled/grooved discs are pretty pointless IMO.
Edited by vrsTom
  • Like 1
Link to comment
I did think it was prob the traffic driving with the ds2500
As when the roads open up the octy does bring speeds down VERY well
Where im guessing then, the zaf is fully built to stop at a tap around town, that said the zafs get abit more spongy n soft if give it some naughties :D
  • Like 1
Link to comment
I destroyed my last set of pads :D
They crumbled when they were tsken out :(
And the replacements from them just didnt work, faded at a thought :(
But that said they were a " dude ur pads just fell apart go find some down the road " situation on a saturday :D
Link to comment
As someone who also drives a zafira regular i can argee that the brakes are keener.
I think the zafira has "extra" technology that helps apply more pressure when you press the pedal maybe? I use a 2008 SRi diesel 150
  • Like 1
Link to comment
Alot a newer cars are the same tbh. My dads peugeot van is even worse then the zafira.
Ive seen you post yours on instagram :)
No tuning here, its my mums and i only use it to walk the dog and take my mum places as shes suffering from dizzy spells so doesnt want to drive.
Link to comment
alot of newer cars/vans have huge braking power at lower speeds, to avoid those low speed traffic light shunts -
work fleet of Connects stop instantly below 25mph, but at motorway speeds - you better hope you dont need to pull up in a big hurry.. all you get is a feeling of pushing on a lovely fluffy sponge cake! which is why i drive along in it constantly watching for evasive manoeuvring routes outa trouble should it arise..
Link to comment
Might be worth checking the plastic brake servo vac pipes for splits/cracks just to be on the safe side, mine cracked about 3 years ago on a 53 plate octy Vrs.
My car is still running the original pads and discs it was supplied with eleven and a half years ago (they still look brand new, like the day we drove it out of the showroom), and they always catch me out and throw you forward in the seat when you touch the brake pedal.
Link to comment
Its just had a mot if that helps, and at speeds its very good
I warped my oem discs and my original pads fell apart the other year :(
At 18k id like to think nothing sinister has happend
I will get the guys to peek at the line tho when in for its service
Link to comment
Id say the oem pads disintegrated form old age and lack of use :rofl:
The oem discs came off mine early this yr - had 150k miles on them and looked it - worn down to half the thickness the new pagids were...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
