LCR/TT HUBS AND WISHBONES
andy68
Recommended Posts
Read through quite a few topics on this conversion, only part I'm not to clear on is, can I use VRS track rods and ends or do I need to swap for LCR/TT ones, from what I can make out VRS ones can be used but you have to swap the ends to the opposite side and that they face down, not up, can those of you that have done this please confirm.
Link to comment
Share on other sites
Yes you can use vrs track ends upside down. This is to fit to TT hub as the TT hub has those connection points slightly higher up. But to me if you are fitting the TT hub and wishbones then you might as well fit the TT rack as this is what gives you tighter turn in because of the quicker lock to lock.
Link to comment
Already got the rack on, just in process of of getting the last couple of bits together to put hubs,wishbones and gearbox with Quaife on, then go and have some FUN :dance:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
