help , forge front mount intercooler
Raj M
Recommended Posts
Hai
      i want to know one thing from an expert about forge front mount inter cooler part number (FMSKOFMIC) , can i fit this intercooler on my stock crashbar , or this will fit only on the carshbar forge supply ?
im ready to do slight modification , i want to know whether its possible or not. Please help :)
Link to comment
Share on other sites
As above the crash bar has been modified by forge to have a number of changes. A few are screw points to hold the cooler. Also the inside of the drivers side crash bar has been cut out to allow the fmic hose to feed through it to connect to the throttle side. And then also forge cut out many holes under top of crash bar to get more air to cooler. Not impossible to do but not easy either. Best is to line the fmic up to the back of the crash as you will be able to see what needs doing straight away. The cooler is secured by 4 screws, 2 on top and 2 at each side ( can see the fixing holes on the cooler as a guide to see where to cut.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
