reading fault codes
Recommended Posts
So I put my car back on the road after surgery this week, and was out driving down the m62 when the glow plug light starts flashing on the dash, I get home, come onto my favourite forum and find out it could mean that the brake light sensor underneath the brake pedal could be faulty, so me & the boy go outside and with him pressung the pedal there is an intermittent fault, so I think its time to buy a fault code reader which will also reset them once read. I don't have loads of cash atm so found this on eBay. Is it any good for my purposes or do I need something else for my 2002 mk1 asv engined TDI 110hp estate?
http://pages.ebay.com/link/?nav=item.view&id=271398142191&alt=web
It has never done this beforeand it kept going off, could it be because the car was laid up for a month?
Link to comment
Share on other sites
Yep it's a doddle, literally open the door, pull down the cover, locate the switch above the peddle then twist it one way or the other, don't force it then it should pop out, unclip the switch, attatch the new switch and reverse what you just done less than 5 minute job
Link to comment
When installing the new switch twist it into position until you hear it click. If it doesn't click it won't work. Do not press the brake pedal during fitting. Switch is fit once only so get it right or you'll be buying twice.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
