Power socket
Recommended Posts
as in where is the fusebox or which one is the fuse?
the fuse box is behind the panel on the right hand side of the car looking towards the front. when you open the door, you can see a blanking panel at the end of the dashboard.
that pries off, and the fusebox is located there. there is a handy reference thingy in there as well to locate the individual fuse.
also check out the owners manual at http://www.skoda.ie/owners/ownersmanuals/superb
Link to comment
Share on other sites
I have the same problem with the front and rear passenger power socket, in the manual it quotes the left hand side of the car which has nothing behind it, the one on the drivers side has an airbag logo on it, is this the correct one.
Thanks jason
Edited by jaystevens1971
Link to comment
The manual is written for the European market so is for left hand drive cars. The fuse box is located behind the end panel of the dash at the drivers side..... So on the right hand end on UK cars.
Link to comment
Thanks jason
Yes. It will have a little rectangular cut out. If you don't gave any trim removal tools you can stick your car key in there and lever the bottom of the fuse cover so that it pops out. Then work your way around the side to the top, prising the cover out with your fingers.
There isn't an airbag in the fuse box.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
