Fabia sdi polo tdi engine swap
Recommended Posts
Hi guys new here my mate was selling me his 9n polo tdi for a couple hundred as the body is totally wrecked but mechanicals are perfect.
My car - 2002 fabia 1.9 sdi
His car - 2003 9n polo tdi pd130 engine
Could I do a straight swap of the engine or what needs to be done to turn my sdi into a tdi??
I have the full car so all parts available.
Thanks in advance
Link to comment
Share on other sites
You basically need everything under the bonnet including the engine loom and the ECU, I think the exhaust might be different as well.
Use your eyes and change everything that's different.
What do you mean your mate WAS selling you the car, either he did or he didn't!
Link to comment
Oh ok I thought it may just of been a simple engine swap not wireing loom and ecu but that's not a problem tbh.
And was selling me it because I turned him down but now I'll just tell him I'll take it.
Is the engine mounts etc the same isn't it?
Does the sdi share anything with the tdi version? Or does everything need to be swapped?
Thanks for ur reply
Link to comment
Btw I meant like a 1.8t conversion everything is different so it needs to be all replaced like fuel pump ecu wireing loom speedo that kinda stuff.
Yes. Everything is basically different. The engine mounts will fit your bodyshell. Your fuel tank will be fine.
Just swap it all over, if the cars are side by side then it's easy.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
