New Monte Carlo Owner From Wales.
bignorm
Recommended Posts
The lock/Unlock audiable sound
Needle sweep
Large mph display (maxidot)
Tear drop wipe on wipers
Increase number of signal flashes on indicacating
Sent from my SM-N9005 using Tapatalk
+1!
And a few more...
-Steering weigh can be adjusted.
-emergency braking indicator flash.
Im sure theres more that i cant think of atm.
Here.. Have some bed time reading
http://www.briskoda.net/forums/topic/239114-fabia-vcds-options/
Link to comment
Share on other sites
What is the tear drop wipe ?
When you use the windscreen washers the wipers sweep the screen a preset amount of times to clear it, when they finish water often settles on the screen and leaves streaks. The 'teardrop' wipe sweeps the screen aprox 3-5 seconds after the last sweep to remove any smudges.
  • Like 1
Link to comment
These sorts of things we should be able to select via a menu on the radio or something.
I had a Citroen C4 and could for example I could switch on or switch off the hijacking feature from there.
Link to comment
It's all things the dealer 'should' ask prior to handover as they are personalised options that are meant to be activated/deactivated on PDI and prep. (they won't change the country for speedo though)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
