Squeal like a piggy
Recommended Posts
Gutted as my trusty Octy (had it 5 years now) sounds like a banshee being abused whenever I brake to a stop.
I think it's the rears, as if I apply the handbrake and come to a slow from speed it squeals a lot.
The rear discs and pads were replaced last year by me (can't remember the make I used).
I've decided to start cleaning up the rears to see if that solves it.  The rear discs have a corrosion lip which I got rid off and I managed to clean the drivers side before it got dark.  Nothing was catching and the piston went back in easy enough with the rewind tool.
When it came to the brake test after putting it back together: Initial braking I had no squeak.  Applied the handbrake a few times and it was squeak city!!
I have ordered some of those return springs off ebay and I am going to have a nosey at the handbrake assembly tomorrow.
Are there any other areas I should check out too??
It's driving me nuts.
Link to comment
Share on other sites
Have you applied a little Copper Slip (Copper Grease) on the rear of the Brake pads?
Just a standard thing to do when fitting pads, & again after time.
george
Edited by goneoffSKi
Link to comment
Whoop the squeal has gone!!
Cleaned the passenger side rear up and all is well. Gave the handbrake assembly a good clean up too. Going to leave using it that until my springs turn up.
I know it's a parking brake but it's a good test to see where the squealing is coming from.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
