Gears seized
skovrs
Recommended Posts
Hi everyone has anyone had problems with gear selector seizing up due to lack of use as mines has went that way was little stiff when a bought it but wasn't used a lot then once a got the car it got better with use age but with me not using it for ages it has pretty much seized up completely any help........
Link to comment
Share on other sites
I had the same.
Mine went unused for 5 months and it was like treacle.
I wipped off the gear stick cover and white greased the mechanism, then I also did the gear linkage adjustment (search on here for how to do this).
After both of those things, I finally resorted to changing the gearbox oil.
After another 200 miles with the new oil and it's finally back to normal. It needed some use and probably some heat along with the new oil, to grease up the gearbox insides.
Link to comment
I had the same.
Ok bud al give that a try the mora and see how a get on do you have a link for the gear linkage adjustment??
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
