starting problems when hot
Recommended Posts
thanks Mike
as with you I can live with the slow starting ok, but I am just getting concerned about the rough idle
I will get battery checked 1st
then as suggested by other member, get it scanned with VCDS
Oscar
Edited by oscarlab
Link to comment
Share on other sites
Low cranking speed when hot ? On the 2.0 tdi the injector wiring requires disconnecting then crank it over when it's hot and read the cranking speed. Can't remember exact figure but think it's something like a minimum of 250 to 300 rpm. If yours reads low suspect starter motor or battery. You will not get a code for this btw.
Edited by FLAPPERJACK7
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
